Use inventors existing command icons in add-in
matt_jlt
matt_jlt
Is there any way to use existing command icons in my addins for Inventor? I make my own icons for lots of commands but for some I would like to just re-use existing Inventor ones for some just because it's fast and easy.
Thanks, Matt.
YuhanZhang
You can extract Inventor built-in icons using below sample, but good practice is to not use the built-in icons to make confusion to users, if you want to re-use Inventor built-in command controls in your own ribbon panels you can directly add them to your panels:
Sub ExtractBuiltInIconSample()
    Dim oDef1 As ButtonDefinition
    Set oDef1 = ThisApplication.CommandManager.ControlDefinitions.Item("PartFilletCmd")
    Dim oIcon As IPictureDisp
    Set oIcon = oDef1.LargeIcon
    StdFunctions.SavePicture oIcon, "C:\temp\Fillet.bmp"
End Sub
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
matt_jlt
Thanks for your help, much appreciated. The command I wanted to use is the view cube fixed distance one that doesn't have a ribbon button and is just from the view-cube context menu so I just wanted to use the view-cube icon to make it easy to identify and not have to waste time drawing up the icon.
Thanks, Matt.
