Use AddUcsToUcs constraint in C#
sanjeevwagle
sanjeevwagle
I am new to inventor programming.
I have written a small iLogic code for making an assembly. In it I have used constraint.AddUcsToUcs call for constraining and it works perfect. Now I intend to translate this code to VC# program. However, I am unable to access constraint.AddUcsToUcs function.
I would appreciate inputs from the experienced forum members.
A snap of the iLogic code is attached herewith.
Thanks in advance.
Sub AddParts()
 Dim asmDoc As AssemblyDocument
 asmDoc = ThisApplication.ActiveDocument
 Dim oAsmCompDef As Inventor.AssemblyComponentDefinition
 oAsmCompDef = asmDoc.ComponentDefinition
 ' Set a reference to the transient geometry object.
 Dim oTG As Inventor.TransientGeometry
 oTG = ThisApplication.TransientGeometry
 'Create a matrix.
 Dim oMatrix As Inventor.Matrix
 oMatrix = oTG.CreateMatrix
 'place an instance of the component
 Dim oOcc1 As ComponentOccurrence
 oOcc1 = oAsmCompDef.Occurrences.Add("C:\Users\TEST\Documents\Inventor Samples\smw_shell.ipt", oMatrix)
 oOcc1.Name = "Main Shell"
 Dim oOcc2 As ComponentOccurrence
 oOcc2 = oAsmCompDef.Occurrences.Add("C:\Users\TEST\Documents\Inventor Samples\smw_dish.ipt", oMatrix)
 oOcc2.Name = "Top Dish"
 'place an instance Of the Component
 Dim oOcc3 As ComponentOccurrence
 oOcc3 = oAsmCompDef.Occurrences.Add("C:\Users\TEST\Documents\Inventor Samples\smw_dish.ipt", oMatrix)
 oOcc3.Name = "Bottom Dish"
 asmDoc.Update()
 Call Constraints.AddUcsToUcs("UcsToUcs1", "Main Shell", "StartUCS", "Top Dish", "ItemUCS", xOffset := 0, yOffset := 0, zOffset := 0)
 Call Constraints.AddUcsToUcs("UcsToUcs2", "Main Shell", "EndUCS", "Bottom Dish", "ItemUCS", xOffset := 0, yOffset := 0, zOffset := 0)
 Call Constraints.AddUcsToUcs("UcsToUcs3", "Main Shell", "StartUCS", "Nozzle", "ItemUCS", xOffset := 0, yOffset := 0, zOffset := 0)
End Sub
chandra.shekar.g
Autodesk Support
Autodesk Support
@sanjeevwagle,
AddUcsToUcs method is available in Autodesk.iLogic.Interfaces.dll.(Inventor 2019 API). The dll is available at installed path of Inventor 2019 (In my system, it is available at "C:\Program Files\Autodesk\Inventor 2019\Bin" location).For more details, refer below help documentation link.
https://help.autodesk.com/cloudhelp/2019/KOR/Inventor-iLogic/iLogic_API/html/e5189a51-4c90-4826-c10d...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
