URDF-Converter
URDF-Converter
GeorgK
Advisor Advisor
Message 1 of 14
URDF-Converter
GeorgK
Hello together,
is there a way to convert assemblies into Universal Robot Description Format (URDF)?
I found a program which do it for a simple robot. Is it possible to do it for any structure or is there a direct way to do this like in SolidWorks?
https://github.com/rjvallett/URDF-Converter
Georg
Replies (13)
Message 2 of 14
Vladimir.Ananyev
You have to develop your own application for this purpose.
BTW it would be nice to see it on the Autodesk App Store...
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 3 of 14
GeorgK
Hello Vladimir,
it would be great if Autodesk could do the job 🙂 Solidworks has this function!
Georg
Message 4 of 14
Vladimir.Ananyev
it’s always a good idea to add this type of request to the ideastation, to make sure it gets additional support and exposure:
http://forums.autodesk.com/t5/inventor-ideastation/idb-p/v1232
best regards,
Vladimir Ananyev
Message 5 of 14
GeorgK
Hello Vladimir,
is it possible to convert the Plugin from SolidWorks to Inventor?
https://bitbucket.org/brawner/sw2urdf/downloads
There is another sample for Inventor:
Georg
Message 6 of 14
Vladimir.Ananyev
Could you look at the pair of manuals at the bottom of the following page:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1079044 ?
Solidworks to Autodesk Inventor Guide
Client Graphics in Autodesk Inventor
cheers,
Vladimir Ananyev
Message 7 of 14
TimXHL4R
I just submitted an application called RoboVerter to AutoDesk.  It will convert Inventor assemblies to URDF files.  It should be available in the app store in a week or so assuming it gets approved.
Message 8 of 14
GeorgK
Hello @TimXHL4R,
that's great. Can you please post if it is available?
Thank you
Georg
Message 9 of 14
Hey,
Is it available now?
Thanks !
Pradheep
Message 10 of 14
For anyone strongly desiring this conversion, PickNik Consulting is very interesting in building this. We would continue the development and maintenance of the existing effort from a few years ago (https://github.com/rjvallett/URDF-Converter). We maintain the Solidworks  to URDF converter and have the software expertise to build this out an Inventor approach for a client.
Message 11 of 14
TimXHL4R
I would be glad to help with anything I can.  The program I made worked well the last time I checked, the only issue was with STL scaling on export.
Unfortunately, I have been working on other projects lately and have not had time to put the finishing touches on mine.
Here is the link to the repository --> https://bitbucket.org/entelechysolutions/roboverter
The repository has both the .bundle file for installing the plugin and the source files.
Message 12 of 14
Download RoboVerter.bundle. I put the roboverter.bundle as in
C:\Program Files\Autodesk\ApplicationPlugins\RoboVerter.bundle
or
C:\Users\$myusername$\AppData\Roaming\Autodesk\Inventor 2013\Addins\RoboVerter.bundle
Inventor 2013 was restarted and it looks like that roboverter is not added.
What should be done to get it added as plug-in?
Thanks.
Message 13 of 14
jrohit1110
Hi! @GeorgK I am using Fusion 360 to URDF converter, but its time consuming for remapping all the joints, etc. But it works well...
https://github.com/syuntoku14/fusion2urdf
Warm Regards,
Rohit Kumar J
Message 14 of 14
GeorgK
@jrohit1110  Thank you for the information.
