Updating user parameter with ilogic
ejaL9K8H
Message 1 of 22
ejaL9K8H
Hi
I am trying to change the user parameter of an Asset model from an Assemply.
I would like my user paramter "ID_Number" to be equal to to the item number from the Bill of Materials.
I have used folowing code, but every time i run it, Inventor freezes and crashses...
What is the problem?
Thanks in advance
doc = ThisDoc.Document
Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition
Dim oBOM As BOM = oAssyDef.BOM
oBOM.StructuredViewEnabled = True
Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured")
' Set the Row Merge Settings
oBOM.SetPartNumberMergeSettings(False)
Dim oBOMRow As BOMRow
For Each oBOMRow In oBOMView.BOMRows
    'Set a reference to the primary ComponentDefinition of the row
    Dim oCompDef As ComponentDefinition
    oCompDef = oBOMRow.ComponentDefinitions.Item(1)
    Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName
    Dim CompFileNameOnly As String
    Dim index As Integer = CompFullDocumentName.LastIndexOf("\")
    CompFileNameOnly = CompFullDocumentName.Substring(index + 1)
	ItemNumber = oBOMRow.ItemNumber
 	Parameter(CompFileNameOnly, "ID_Number") = ItemNumber
Next
Replies (21)
Message 21 of 22
Ralf_Krieg
Hello
Can you try to replace the line
New_Value = Parameter(oDoc.Name, "ID_Number") & " - " & iProperties.Value(oDoc.Name, "Project", "Part Number")
with this line
New_Value = GetNewValue(oDoc)
and add the following function somewhere to the end of your iLogic Script
Private Function GetNewValue(oDoc As Document) As String
Dim oUserParams As UserParameters
Set oUserParams = oDoc.ComponentDefinition.Parameters.UserParameters
Dim oUserParam As UserParameter
For Each oUserParam In oUserParams
    If oUserParam.Name = "ID_Number" Then
        New_Value = oUserParam.Value
        Exit For
Next
Dim oPropSet As PropertySet
Set oPropSet = oDoc.PropertySets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")
Dim oProp As Property
For Each oProp In oPropSet
    If oProp.Name = "Part Number" Then
        New_Value = New_Value & " -" & oProp.Value
        Exit For
Next
GetNewValue = New_Value
End Function
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 22 of 22
ejaL9K8H
Error in rule:
Parameter: The document named "C:\Working Folder\Designs\Factory Assets\Test_5C934505E5A8EC1FD6ED745FF98CBFF6.ipt" was not found.
But it workes fine if I just give the Asset Tag a emty name:
New_Value = ""
So you are rigth that the problem is that line.
But this is enough for my needs. Thanks a lot!
