Updating part file parameters with Python
20854706
Message 1 of 9
20854706
Dear forum users,
Is there a way to use Python to update certain parameters within a part file in Inventor? I've searched the forum, and the closest I could come to a solution is a post about adding missing parameters, which is not what I want to do.
Any help would be extremely helpful.
Kind regards
Replies (8)
Message 2 of 9
JelteDeJong
this rule will update a parameter
import win32com.client
from win32com.client import gencache, Dispatch, constants, DispatchEx
ThisApplication = win32com.client.Dispatch('Inventor.Application')
ThisApplication.Visible = True
CastTo = gencache.EnsureModule('{D98A091D-3A0F-4C3E-B36E-61F62068D488}', 0, 1, 0)
ThisApplication = CastTo.Application(ThisApplication)
oDoc = ThisApplication.ActiveDocument
oDoc = CastTo.PartDocument(oDoc)
params = oDoc.ComponentDefinition.Parameters
parameter1 = params.Item("MyParameterName")
print("number of Parameters: ",parameter1.Value)
parameter1.Value = 2.0
Jelte de Jong
Blog: hjalte.nl - github.com
Message 3 of 9
20854706
@JelteDeJong Thank you for your reply. It works! Although, while the parameter updates, the part does not. Is there a way to force the update rather than manually clicking on the "Update" button on the Manage tab?
My goal is to update the whole part with the new values, then export it as a .stl file after all the updates have happened.
Is it possible to make this all automatic?
Message 4 of 9
JelteDeJong
you can try:
oDoc.Update()
oDoc.Update2()
Jelte de Jong
Message 5 of 9
20854706
@JelteDeJong Thank you again for the quick reply. The first line worked!
The last thing that I'm struggling with is exporting the file after I made the updates to the parameters. Is there a possible way of doing this?
Message 6 of 9
JelteDeJong
what do you mean by exporting? do you want to create dxf's or pdf's?
Jelte de Jong
Message 7 of 9
20854706
@JelteDeJong, I want to export the part as a .stl file type.
Message 8 of 9
JelteDeJong
try this:
newFileName = "d:\\temp\\test.stl"
oDoc.SaveAs(newFileName, True)
Jelte de Jong
Message 9 of 9
20854706
Thank you very much! You've been a great help!
