Update View Labels on current sheet
J_Dumont
J_Dumont
I could some assistance with the following code. The program updates all of the views on all sheets properly.
However, I would like the option to process the current sheet only.
Here is my current code.
Dim oDoc As DrawingDocument:  oDoc = ThisDoc.Document
oModel = ThisDoc.ModelDocument
Dim oSheets As Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
oSheets = oDoc.Sheets
	If question1=vbNo Then
			For Each oSheet In oSheets
			oViews = oSheet.DrawingViews
			    For Each oView In oViews
			    'make view label visible
			      If oView.ViewType = 10501 Then
				oView.ShowLabel = True
				oView.Label.FormattedText = String1 & String2 & "<Br/>" & String4 &"<Br/>" & String3
			    Next
			Next
			Else
		    Next
R.Mabery
I don't see where your question1 is getting it's information from but......below I commented out the lines that you don't need just to show what I changed.
If you only want to work with the current sheet (or active sheet) then you don't need to loop through the Sheets collection.  Therefore, I commented out the For / Each loop.
'Dim oSheets As Sheets
Dim oSheet As Sheet
'oSheets = oDoc.Sheets
oSheet = oDoc.ActiveSheet
'	For Each oSheet In oSheets
		Next
'	Next
Else
	Next
Randy Mabery
Applications Expert
IMAGINiT Technologies
WCrihfield
Here's something you can try:
Sub Main
	Dim oDoc As DrawingDocument = ThisDoc.Document
	Dim oSheet As Sheet = oDoc.Sheets
	If MsgBox("All Sheets [Yes] Or ActiveSheet [No]?", vbYesNo + vbQuestion,"") = vbYes Then
			UpdateLabels(oViews)
		Next
	Else
End Sub
Sub UpdateLabels(oVws As DrawingViews)
	For Each oView As DrawingView In oVws
	Next
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
J_Dumont
Hi Randy,
My apologies, I left the code for the question out of my post. I removed the comments and the code works perfectly.
Thank you for the quick response.
J_Dumont
Thank you as well for posting so quickly. I like your style but for whatever reason, the code errors with the following message.
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.Sheet'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{206B59AE-22A6-11D4-B7A8-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Here is the code I am using.
Sub Main
sFont = "Arial"
sFSize1 = 0.3 'font size in cm
sFSize2 = 0.3175 'font size in cm
String1 = "<StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "' Underline='False'> PN: </StyleOverride><StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "' Underline='False'><Property Document='model' PropertySet='Design Tracking Properties' Property='Part Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='43'>PART NUMBER</Property></StyleOverride><StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'> - </StyleOverride>"
String3 = "<StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'>SCALE: </StyleOverride><StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'><DrawingViewScale/></StyleOverride>"
String2 = "<StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "' Underline='False'><Property Document='model' PropertySet='Design Tracking Properties' Property='Authority' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='43'>AUTHORITY</Property></StyleOverride><StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'> REQ&apos;D </StyleOverride>"
String4 = "<StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'><Property Document='model' PropertySet='Design Tracking Properties' Property='Material' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='20'>MATERIAL</Property></StyleOverride><StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'> - </StyleOverride><StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'><Property Document='model' PropertySet='User Defined Properties' Property='G_H' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='7'>G_H</Property></StyleOverride><StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'> THK</StyleOverride>"
Dim oSheet As Sheet=oDoc.Sheets
		Next
		Else
End Sub
	For Each oView In oVws
	Next
End Sub
WCrihfield
You're right.  I see it very clearly now this morning.  It's right near the top where we are creating the variables.  We need to change this:
to this:
Dim oSheets As Sheets = oDoc.Sheets
Dim oSheet As Sheet
Apparently I accidentally put that Value behind the wrong variable, so it was thinking we were trying to set a Sheet type variable to a Sheets type value, which caused the error.  Hopefully that fixes the error and there aren't any others.  Sorry about that. 🙃
Wesley Crihfield
