Update to FX Auto-Populate Code
harvey3ELEA
harvey3ELEA
I'm looking to take this excellent code supplied by Curtis W. and have it auto-populate my FX parameters at part level.
Currently, I have to drop a part or parts into an assembly to have this run properly, which works great, but I'm looking to eliminate that assembly requirement for individual parts.
While I can sometimes tweak a routine successfully, I'm not good enough at ilogic coding to understand how to do this.  Suggestions welcome...
Sub Main
	Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oOccs As ComponentOccurrences = oADoc.ComponentDefinition.Occurrences
	'step into sub with the target occurrence being the the top level assembly
	Call TraverseAssembly(oOccs)
End Sub
Sub TraverseAssembly(oOccs As ComponentOccurrences)
	Dim oOcc As ComponentOccurrence
	For Each oOcc In oOccs
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			'step back into this sub with the target occurrence being the subassembly
			Call TraverseAssembly(oOcc.SubOccurrences)
		Else 'parts
			Dim partDoc As PartDocument = oOcc.Definition.Document
			If Not partDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For' Check if sheet metal part
			'step into sub routine
			Call FlatExtents(partDoc)
	Next
End Sub
Sub FlatExtents(partDoc As PartDocument)
	Dim oCompDef As SheetMetalComponentDefinition = partDoc.ComponentDefinition
	If oCompDef.HasFlatPattern = False Then
		oCompDef.Unfold
		oCompDef.FlatPattern.ExitEdit
	oA = oCompDef.FlatPattern.Length
	oB = oCompDef.FlatPattern.Width
	oFlat_Length = Max(oA, oB)
	oFlat_Wdith = Min(oA, oB)
	' Get the parameters of the component definition
	Dim params As Parameters = oCompDef.Parameters
	' Check if parameters "LENGTH" and "WIDTH" exist, update or add them
	Try
		params.UserParameters.Item("LENGTH").Value = oFlat_Length
	Catch
		params.UserParameters.AddByValue("LENGTH", oFlat_Length, "in")
	End Try
	Try
		params.UserParameters.Item("WIDTH").Value = oFlat_Wdith
	Catch
		params.UserParameters.AddByValue("WIDTH", oFlat_Wdith, "in")
	End Try
	' Set parameters to be exposed as properties
	params.Item("LENGTH").ExposedAsProperty = True
	params.Item("LENGTH").CustomPropertyFormat.Units = UnitsTypeEnum.kInchLengthUnits
	params.Item("LENGTH").CustomPropertyFormat.Precision = CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision
	params.Item("LENGTH").CustomPropertyFormat.ShowUnitsString = False
	params.Item("WIDTH").ExposedAsProperty = True
	params.Item("WIDTH").CustomPropertyFormat.Units = UnitsTypeEnum.kInchLengthUnits
	params.Item("WIDTH").CustomPropertyFormat.Precision = CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision
	params.Item("WIDTH").CustomPropertyFormat.ShowUnitsString = False
	params.Item("Thickness").ExposedAsProperty = True
	params.Item("Thickness").CustomPropertyFormat.Units = UnitsTypeEnum.kInchLengthUnits
	params.Item("Thickness").CustomPropertyFormat.Precision = CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision
	params.Item("Thickness").CustomPropertyFormat.ShowUnitsString = False
	iProperties.Value(partDoc.DisplayName, "Custom", "LENGTH") = "=<Sheet Metal Length>"
	iProperties.Value(partDoc.DisplayName, "Custom", "WIDTH") = "=<Sheet Metal Width>"
End Sub
Curtis_Waguespack
@harvey3ELEA, if you're running this as an external rule, you can just replace the Main sub with this and it will work for assemblies or parts, or you could use the 2nd example on just parts
use this for parts and assemblies ( replace the main sub in your original rule with this)
Sub Main
	Dim oDoc As Document = ThisDoc.Document
	If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
	ElseIf oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
		If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
			Call FlatExtents(oDoc)
End Sub
Use this for only parts ( use this as the entire rule)
Dim partDoc As Document = ThisDoc.Document
	oCompDef.Unfold
Try
Catch
End Try
Try
Catch
End Try
harvey3ELEA
Thanks, Curtis.  I'm seeing this error however when I implement your parts-only code from above into a new external rule on a dummy 6" x 4" x 1/2" plate .  Not sure what the error is telling me:
Curtis_Waguespack
ooops! try this version
If Not partDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Exit Sub
	oCompDef.Unfold
Try
Catch
End Try
Try
Catch
End Try
iProperties.Value("Custom", "LENGTH") = "=<Sheet Metal Length>"
iProperties.Value("Custom", "WIDTH") = "=<Sheet Metal Width>"
harvey3ELEA
Works great.  Thanks for that quick code fix for individual parts.
As always, I appreciate your time & efforts.
Harvey
