Update styles
Update styles
hEINSTEIN
Update styles
hEINSTEIN
I have a text document which I can import to update my styles in the idw environment.
Is it possible to do this with iLogic for multiple files?
《iLogic Rule Batch Tool》in atuodesk app store
Andrii_Humeniuk
Hi @hEINSTEIN again. This question is quite widespread and there is no direct solution. Check out the following links: link , link .
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
hEINSTEIN
I am planning to use that tool, I just don't know how to write the rule
I got it from another post,This code is a set of rules for handling styles in drawing documents. It includes functions to import template file settings into the target document, update styles in the document, replace object default styles, and delete unused styles. By executing these steps, it ensures that the document's styles are consistent with the template file and removes styles that are no longer in use.
hEINSTEIN
I get this error, do you know how I can fix it?
Can you send a test file:
