Update style from Library
Hello.
I've some old drawing that I want to update.
Actually I update the styles manualy, but I want to make it with iLogic.
I do :
1.  Update styles, check all, yes for all, OK.
2.  Purge styles, check all, yes for all, OK.
Can I do it with some iLogic code ?
Best regards.
NSBowser
This should help you update the styles. I don't see anything in the API which can 'purge' the styles, but maybe someone else can add something here to handle that.
iLogicVb.UpdateWhenDone = True
Dim oFile As String
Dim oFileDlg As Inventor.FileDialog
Try
    InventorVb.Application.CreateFileDialog(oFileDlg)
    With oFileDlg
        .DialogTitle = "Select the Drawings to Update"
        .Filter = "Autodesk Inventor Drawing (*.idw)|*.idw"
        '.SuppressResolutionWarnings = True
        '.OptionsEnabled = True
        .MultiSelectEnabled = True
        .CancelError = True
        .ShowOpen()
    End With
Catch
    Return
End Try
Dim FileList As New List(Of String)(oFileDlg.FileName.Split("|")) For Each oFile In FileList If oFile <> "" Then OpenDoc = ThisApplication.Documents.Open(oFile,False) oStyles = OpenDoc.StylesManager.Styles For Each oStyle As Style In oStyles If Not oStyle.UpToDate Then oStyle.UpdateFromGlobal End If Next Try OpenDoc.Save Catch MessageBox.Show("Failed to Save Document:" & vbCr & oFile) End Try Try OpenDoc.Close Catch End Try End If Next MessageBox.Show("Style Update Complete")
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
That works fine, thank's !
Still waiting for a purge function.
nkirton
Im still new to iLogic so my ability to edit this code is limited.
If I don't want to have the window show up for a selection, and just have inventor use the current open drawing, how do I have to edit the code? I know I need to remove this...
Try
    With oFileDlg
        .CancelError = True
        .ShowOpen()
    End With
Catch
    Return
End Try
 But how do I tell Inventor to use the current document.
Thanks!
Nathan Kirton
If what I said helped you out, please use the ACCEPT AS SOLUTION or KUDOS buttons.
"I don't know why it doesn't work. It fit in the model!"
nkirton
So I got it haha!
This rule will run and update the current open drawing styles to the global styles.
and then saves it...
Sub Main()
        OpenDoc = ThisDoc.Document
        Next
        Try
            OpenDoc.Save
        Catch
        End Try
    End Sub
Nathan Kirton
