Update Partslist in IDW is slow
We developed an Inventor-Addin, in this addin we update cells in the partslist like this:
foreach (PartsListRow partsListRow in partsList.PartsListRows)
   // this takes to long
    partsListRow[ConfigurationConstants.InventorPartslistItemItemIdColumnKey].Value = string.Empty;
in a small drawing everything is ok, but we have drawings with over 80 position then this command takes everytime 10 seconds and because we update 2 cells in each row this goes up to more then 30 minutes.
the same can be reprodused using a smal macro like this.
Any help would be welcome!
Sub UpdateZelle()
Dim partsList As partsList
Dim partsListRow As partsListRow
Dim drawing As DrawingDocument
Dim partsListCell As partsListCell
Set drawing = ThisApplication.ActiveDocument
Set partsList = drawing.ActiveSheet.PartsLists(1)
For Each partsListRow In partsList.PartsListRows
    partsListRow("ItemID") = ""
Next
End Sub
Regards
Daniel
DeerSpotter
Why not create a Universal Update Code?
 'Define the open document
Dim openDoc As Document
openDoc = ThisDoc.Document
'Look at the model file referenced in the open document
Dim docFile As Document
If ThisDoc.ModelDocument IsNot Nothing Then
docFile = ThisDoc.ModelDocument
Else
MessageBox.Show("This drawing has no model reference", "iLogic")
Return
iLogicVb.UpdateWhenDone = True
InventorVb.DocumentUpdate()
InventorVb.DocumentUpdate(iProperties.Mass)
'InventorVb.DocumentUpdate(iProperties.Material)
'format model file name
Dim FNamePos As Long
FNamePos = InStrRev(docFile.FullFileName, "\", -1)
Dim docFName As String
docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
Image and video hosting by TinyPic
See My LinkedIn Profile
Thank you for your answer.
We have some special properties witch are not related to any model information. We just need to update this properteis in the drawing partslist not in the model.
