update part number on save as with ilogic
I am using ilogic to generate different assembly files. I am doing this by opening a template file then save as (this bit is working fine)
Dim oDoc As AssemblyDocument = ThisApplication.Documents.Open(CurrentFilename & ".iam")
oDoc.SaveAs(oNewName & ".iam", False)
But now i want to change the part number too. I need something like
iProperties.Value(CurrentFilename & ".iam",Project","Part Number") = oNewName
 Any ideas?
clutsa
I had to add document paths to get this to work on my machine but I just change the part number before I SaveAs
oNewName = InputBox("Prompt", "Title", "AssyTemplateSaveTest_")
Dim oDoc As AssemblyDocument = ThisApplication.Documents.Open(ThisDoc.Path & "\AssyTemplateSave.iam")
oDoc.PropertySets("Design Tracking Properties").Item("Part Number").Value = oNewName
oDoc.SaveAs(ThisDoc.Path & "\" & oNewName & ".iam", False)
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
acanx21
If you're just changing it to be the new name, the code should just be:
iProperties.Value("Project", "Part Number") = oNewName
you could also use to get the current model name for the part name
modelFullFileName = ThisDoc.ModelDocument.FullFileName
modelDirectoryName = IO.Path.GetDirectoryName(modelFullFileName)
modelFileName = IO.Path.GetFileName(modelFullFileName)
modelFileNamewithoutextentionsion = IO.Path.GetFileNameWithoutExtension(modelFullFileName)
iProperties.Value("Project", "Part Number") = modelFileNamewithoutextentionsion
Thanks @clutsa That worked a treat.
Do you know if there is a similar command for creation date? something like:
oDoc.PropertySets("Design Tracking Properties").Item("Creation Date").Value = Now
...and how do i learn this stuff without having to post to the forums? I can't find anything in the API Help. Is there an equivalent of vb locals window that lets you browse your objects and variables?
clutsa
Probably looking for...
oDoc.PropertySets("Design Tracking Properties").Item("Creation Time").Value = Now
 VBA local windows are spot-on for how I look most of this up.
https://www.youtube.com/watch?v=MFU_QaGdIDA I believe this video covers what you're asking and then some (it's a bit long but if my memory serves it's worth watching)  I couldn't get it to play just now to verify (our network is $#!t this morning). If it's not helpful let me know and I'll throw together a screen cast.
