Update method in assembly.
breinkemeyer
breinkemeyer
I have an assembly created through the api.  at the end of the routine I do an assemblydoc.update() and an assemblydoc.close().  When I open it I have to do a local update (see attachment).  Is the local update button supposed to be the same as the update method?
Andrii_Humeniuk
Hi @breinkemeyer .
This may be because you are updating but not saving the assembly before closing. Try adding a Save() function before closing the assembly.
assemblydoc.Update()
assemblydoc.Save()
assemblydoc.Close(True)
You can also use the Rebuild function to force a refresh before saving.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
