Update ipart with Ilogic
i would like to update and iPart with an ilogic rule. But I don't know how to process.
I would like to created a rule call partUpdate. In this rule, i would like to switch from a part to an other in. I would like to switch part from a form trigge when the document open. In the form, a cell will be link with a text multi-variable in Parameters. Also, i would like to rule or call this rule in a parent assembly.
Can you help me?
I'm new with Ilogic.
Justin
Sergio.D.Suárez
Hi, Excuse me for not being able to interpret your question. Could you attach an image to describe the behavior you need? regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
johnsonshiue
Hi Justin,
I think you are attempting to do so-called Configuration workflow, right? Depending on how you set up your iLogic rule and the iPart, you may run into issues. To guide you through the process, it is better to have an example of what you are trying to do. The solution can range from easy to hard or even not doable.
Many thanks!
Software Test Engineer
