Update derived part parameters
Hi All,
I'm writing a simple script to update user parameters of a derived part. The derived part already exists, I just want to add all new 'User Parameters'. I thought I had it figured out, but the line where I set "IncludeEntity" to true has no effect. Here's the code below, and the line that doesn't do what I want is highlighted in Red.
I would expect it to change "IncludeEntity" to true, but instead it just leaves it as false. No error messages, the file has read/write access so I'm not sure what else it could be.
Any suggestions?
Dim oapp As Application
Dim oDoc As PartDocument
Dim oDerDoc As DerivedPartComponent
Set oapp = ThisApplication
Set oDoc = oapp.ActiveDocument
On Error GoTo subError
'UPDATE DERIVED COMPONENT WITH ALL USER PARAMETERS
Dim sDerivedComp As String
sDerivedComp = "P00031-001-000.ipt"
If MsgBox("Get User Parameters from " & sDerivedComp & "?", vbYesNo, "Update Derived Component") = vbYes Then
    For Each oDerDoc In oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents
        If oDerDoc.Name = sDerivedComp Then Exit For
    Next
    If oDerDoc Is Nothing Then
        If MsgBox("No derived part named " & sDerivedComp & " found. Would you like to continue?", vbOKCancel) = vbCancel Then GoTo subExit
    Dim DerEnt As DerivedPartEntity
    Dim X1 As Integer
    For Each DerEnt In oDerDoc.Definition.Parameters
        X1 = X1 + 1
        If DerEnt.ReferencedEntity.Type = kUserParameterObject Then
            If oDerDoc.Definition.Parameters(X1).IncludeEntity = False Then
                oDerDoc.Definition.Parameters(X1).IncludeEntity = True
    Next
Jef_E
Hi!
i adjusted my post,
I edited your code so it should work.
        Dim oDerDef As DerivedPartDefinition
            Next
            oDerDef = oDerDoc.Definition
            Dim X1 As Integer
            For Each DerEnt In oDerDef.Parameters
                X1 = X1 + 1
            Next
        oDerDoc.Definition = oDerDef
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
