Update Button update style
I am looking for an way to automatically update style (and perhaps also purge style).
Is there a way to reach the Manage Tab, Styles and Standard Ribbon, Update and Purge with iLogic?
I am unable to install extra addins, I need a solution inside my template.
Thanks in advance,
Arnold
This won't completely answer your question, but see page 9 of this pdf: http://modthemachine.typepad.com/files/Upgrading%20to%20Ribbon.pdf
That code will put all the Inventor ribbon names (and tabs, etc) into a text file for you to reference later.  The rest of that file should give an overview of how to access and customize the ribbons.
For general inventor programming, these 4 Autodesk  blogs are a good read.  I find they make a good start to the workday.
http://modthemachine.typepad.com/   (Inventor programming)
http://adndevblog.typepad.com/manufacturing/   (More Inventor programming)
http://justonesandzeros.typepad.com/blog/   (This one is for Vault)
http://inventortrenches.blogspot.com/    (Often focuses on iLogic)
