Update appearance asset
CadUser46
CadUser46
Cross ref https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/update-all-styles-in-ipt-iam-with-vb...
I have a subset of models that are proving difficult to automate update styles.
What i want is to update "Steel, Mild" to match the library but this does not happen.  It would appear that to do this  manually requires two steps instead of the usual one.
1. Update Styles > Autodesk Appearance Library > Steel, local, yes.
2. Update Styles > Inventor Material Library > Steel, local, yes.
I thought i could force this to work in the api by applying Generic Material, Default Appearance, purge everything then get the Steel, Mild style from the library.  In this subset though the Steel Appearance cannot be deleted, thus it does not get overwritten when i get Steel, Mild from the library.  I have tried manually tracing this style, broken every reference i can find but still it cannot be deleted.
I just need a robust method to ensure the material and colour styles get updated.
rivate Sub PurgeUpdateAssets()
    '  https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/update-all-styles-in-ipt-iam-with-vba/m-p/9612023
    Dim pDoc As PartDocument: Set pDoc = ThisApplication.ActiveDocument
    ' Apply Generic Material
    Dim aGeneric As String: aGeneric = "Generic"
    On Error Resume Next
    Dim mAsset As MaterialAsset: Set mAsset = pDoc.Assets(aGeneric)
    If Err <> 0 Then Set mAsset = GetMatAssetFromLib(pDoc, aGeneric)
    pDoc.ActiveMaterial = mAsset
    On Error GoTo 0
    ' Apply Default Appearance
    Dim aDefault As String: aDefault = "Default"
    Dim aAsset As Asset: Set aAsset = pDoc.AppearanceAssets("Default")
    If Err <> 0 Then Set aAsset = GetAppAssetFromLib(pDoc, aDefault)
    pDoc.ActiveAppearance = aAsset
    On Error GoTo 0
    ' Purge old materials
    For Each mAsset In pDoc.MaterialAssets
        'pDoc.MaterialAssets("Steel, Mild").Delete
        If mAsset.IsUsed = False Then mAsset.Delete
    Next
    For Each aAsset In pDoc.Assets
        Debug.Print aAsset.DisplayName
        If aAsset.IsUsed = False Then aAsset.Delete
    Next
    ' Get new material from library
    pDoc.ActiveMaterial = GetMatAssetFromLib(pDoc, "Steel, Mild")
    Dim Matl As Material: Set Matl = pDoc.Materials.Item("Steel, Mild")
    Call Matl.UpdateFromGlobal
    ' Iterate through the objects that have an override.
    Dim obj As Object
    For Each obj In pDoc.ComponentDefinition.AppearanceOverridesObjects
        ' Set the source of the appearance based on the type of object.
        ' It's possible to use kPartAppearance in all cases, but this sets it to the default source used by Inventor when no overrides exist.
        If TypeOf obj Is SurfaceBody Then
            obj.AppearanceSourceType = kPartAppearance
        ElseIf TypeOf obj Is PartFeature Then
        ElseIf TypeOf obj Is Face Then
        Else
            MsgBox "Unexpected type with appearance override: " & TypeName(obj)
    Next
    pDoc.ComponentDefinition.ClearAppearanceOverrides
End Sub
Private Function GetMatAssetFromLib(oDoc As PartDocument, AssetName As String) As MaterialAsset
    Dim matLib As AssetLibrary: Set matLib = ThisApplication.AssetLibraries.Item("Inventor Material Library")
    Dim libAsset As Asset: Set libAsset = matLib.MaterialAssets.Item(AssetName)
    Set GetMatAssetFromLib = libAsset.CopyTo(oDoc)
    Debug.Print Err.Number
    If Err Then Set GetMatAssetFromLib = libAsset
End Function
Private Function GetAppAssetFromLib(oDoc As PartDocument, AssetName As String) As Asset
    Dim assetLib As AssetLibrary: Set assetLib = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library")
    Dim libAsset As Asset: Set libAsset = assetLib.AppearanceAssets.Item("AssetName")
    Set GetAppAssetFromLib = libAsset.CopyTo(oDoc)
    If Err Then Set GetAppAssetFromLib = libAsset
End Function
Inventor 2010 Certified Professional
Currently using 2023 Pro
A.Acheson
I haven't tested your part but doing this manually. It looks like the styles need to be updated which will bring in the material and the associated appearance. You then need to ensure the appearance has not been overridden in the local document meaning you need to select clear override to follow the material style from the library. Changing  the source appearance is how to do that. Sourced from this post here.  Maybe this will help?
Dim oDoc = ThisDoc.Document
oDoc.AppearanceSourceType = AppearanceSourceTypeEnum.kMaterialAppearance
You could also use the command manager to update material styles similar to the manual activation of the update button.
Regards
Alan
d_dankerl6K5U5
Dim thisDocument As Document = ThisApplication.ActiveDocument
Dim existingRanderStyle As RenderStyle
For Each existingRanderStyle In thisDocument.RenderStyles
If existingRanderStyle.UpToDate = False Then
    existingRanderStyle.UpdateFromGlobal
Next
