Up Down fold count properties
ch_giacomo
ch_giacomo
Good morning everyone, I have modified this rule so that it is compatible with my work (I took the basic rule from this forum).
What I can't do is: if "Bend Up and Bend Down" are present in the properties everything works fine, but if the properties are not present the rule does not create new ones. where is it wrong? Thank you.
Imports Inventor
Public Sub Main()
    Try
        Dim partDoc As PartDocument = ThisApplication.ActiveDocument
        If partDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject AndAlso partDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
            Dim sheetMetalDef As SheetMetalComponentDefinition = partDoc.ComponentDefinition
            If Not sheetMetalDef.HasFlatPattern Then
                sheetMetalDef.Unfold()
            Dim flatPattern As FlatPattern = sheetMetalDef.FlatPattern
            Dim upsCount As Integer = 0
            Dim downsCount As Integer = 0
            For Each bendResult As FlatBendResult In flatPattern.FlatBendResults
                If Not bendResult.IsOnBottomFace Then
                    If bendResult.IsDirectionUp Then
                        upsCount += 1
                    Else
                        downsCount += 1
            Next
            SetCustomProperty(partDoc, "Bend Up", upsCount)
            SetCustomProperty(partDoc, "Bend Down", downsCount)
    Catch ex As Exception
        MessageBox.Show("Errore durante l'elaborazione del documento: " & vbCrLf & ex.Message, "Errore", MessageBoxButtons.OK, MessageBoxIcon.Error)
    End Try
End Sub
Public Sub SetCustomProperty(doc As Document, name As String, value As Integer)
    Try
        Dim userDefinedProps As Object = doc.PropertySets.Item("User Defined Properties")
        Dim customProp As Object = Nothing
        ' Cerca la proprietà utente con il nome specificato
        For Each prop As Object In userDefinedProps
            If prop.Name = name Then
                customProp = prop
                Exit For
        Next
        ' Se la proprietà esiste, aggiorna il valore, altrimenti aggiungila
        If customProp IsNot Nothing Then
           customProp.Value = value
        Else
            userDefinedProps.Add(value, name)
        MessageBox.Show("Errore durante la gestione delle proprietà utente: " & ex.Message, "Errore", MessageBoxButtons.OK, MessageBoxIcon.Error)
    End Try
End Sub
FINET_Laurent
Hi @ch_giacomo,
From what I can tell, the rule is throwing an error when creating a new iProperty. The issue is related to the declaration of unspecified object types for the properties & the property set (which is called evil coding). Declaring the variables with an accurate type for the sub fixes the code :
    Try
        Dim userDefinedProps As Inventor.PropertySet = doc.PropertySets.Item("User Defined Properties")
        Dim customProp As Inventor.Property = Nothing
        For Each prop As Inventor.Property In userDefinedProps
                customProp = prop
                Exit For
        Next
        Else
    End Try
End Sub
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
FINET_Laurent
@ch_giacomo
Implementation of the fixed code :
Imports Inventor
Public Sub Main()
    Try
                        upsCount += 1
                    Else
                        downsCount += 1
            Next
    End Try
End Sub
    Try
                customProp = prop
                Exit For
        Next
        Else
    End Try
End Sub
ch_giacomo
Thank you very much!! I hope it can be useful to others.
