Unsuppress Drawingviews using LINQ
frederic.vandenplas
frederic.vandenplas
I want to (un)suppres drawingviews using LINQ.
When i debug the code in VS the functions seems to work fine but the drawingviews remain (un)suppressed.
Can someone help me out?
First i filter for drawingviews which contains TREK , then i want to (un)suppress them.
Sub main
Dim invapp As Inventor.Application = ThisApplication
Dim oDrawDoc As DrawingDocument = invapp.ActiveDocument
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
oSheet.DrawingViews.Cast(Of DrawingView).ToList().Where(Function(oDrawView As DrawingView) oDrawView.Name.Contains("TREK")).tolist.ForEach(Function(oDrawView As DrawingView) oDrawView.Suppressed = True)
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
WCrihfield
I could be wrong, because I have not tested it, but you may be attempting just a little too much with one line there.  I think you may need a Delegate Sub routine that you can point to for each item in the list at the end, instead of another 'Function(Of T)'.  Just looking at the simple example on Microsoft's website for that List<T>.ForEach() method.  It's using an Action<T> delegate there.
Wesley Crihfield
(Not an Autodesk Employee)
frederic.vandenplas
Indeed, maybe i wanted to much 🙂
I've solved it this way
For Each oDrawView As DrawingView In oSheet.DrawingViews.Cast(Of DrawingView).Where(Function(d As DrawingView) d.Name.Contains("TREK"))
Next oDrawView
