Unknow rule error
Unknow rule error
Remy-intl
Unknow rule error
Remy-intl
I use an Ilogic I use a rule to check if a list "MY LIST" exists in my parts and assemblies files.
I use the trigger to lunch that rules before .ipt and .iam  are saved. With parts and assemblies the rules work well. But If I save some modifications on .ipt or .iam from a drawing (.idw) I have this error.
Message error:  (sorry for the "french")
Erreur de règle: TypeERPListeDéroulante, dans le document 117994.iam
Le membre public 'ComponentDefinition' du type 'DrawingDocument' est introuvable.
I think it's come from this line of the code (full rule is below)
oMyParameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
When I save from the idw the active document is a idw and not an iam or ipt.
Normally the code should not run in the idw.
I think saving the .ipt/.iam runs the rule but it runs at the idw level.
I don't know how can i get around the problem.
Do you have any ideas?
Thanks a lot for your time 🙂
Dim FileName As String
FileName = ThisDoc.FileName()
If FileName <> "" Then
	Try
			otester = oMyParameter.Item("Liste_TypeERP")
		Catch
			oInsulationType = oMyParameter.AddByValue("Liste_TypeERP", "", UnitsTypeEnum.kTextUnits)
			'make parameter a multivalue list parameter
			MultiValue.SetList("Liste_TypeERP", "Machine", "Dont export to ERP", "Part or sub assembly", "Purchase", "Ghost")
		End Try
Michael.Navara
The issue is in ThisApplication.ActiveDocument. This is document which is currently active in Inventor. It is not necessarily the same document, where you run iLogic script.
Use ThisDoc.Document instead
Frederick_Law
Do you want it to run in idw?
If not, set the trigger on ipt and iam only.
Not on the idw or All Files.
Remy-intl
Thanks a lot. It's working well.
