UnitVecor IsEqualTo tolerance units
Josh_Hunt
Josh_Hunt
REFERENCE https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=UnitVector_IsEqualTo
I was guessing tolerance argument was in radian units as the angle between them but is not accurate.
This IsEqualTo method switched from false to true when tolerance is between 1.41 and 1.42. The angle between them is half PI radians.
What 'units' is tolerance?
Maybe I need to learn more Math!
UV_X: 1, 0, 0
UV_Y: 0, 1, 0
UV_X angle to UV_Y = 1.5707963267949 radians
UV_X  isEqualTo  UV_Y ?
    False   (tolerance = 1.3)
    False   (tolerance = 1.31)
    False   (tolerance = 1.32)
    False   (tolerance = 1.33)
    False   (tolerance = 1.34)
    False   (tolerance = 1.35)
    False   (tolerance = 1.36)
    False   (tolerance = 1.37)
    False   (tolerance = 1.38)
    False   (tolerance = 1.39)
    False   (tolerance = 1.4)
    False   (tolerance = 1.41)
    True   (tolerance = 1.42)
    True   (tolerance = 1.43)
    True   (tolerance = 1.44)
    True   (tolerance = 1.45)
    True   (tolerance = 1.46)
    True   (tolerance = 1.47)
    True   (tolerance = 1.48)
    True   (tolerance = 1.49)
    True   (tolerance = 1.5)
    True   (tolerance = 1.51)
    True   (tolerance = 1.52)
    True   (tolerance = 1.53)
    True   (tolerance = 1.54)
    True   (tolerance = 1.55)
    True   (tolerance = 1.56)
    True   (tolerance = 1.57)
    True   (tolerance = 1.58)
    True   (tolerance = 1.59)
Josh Hunt
Michael.Navara
I don't know how the tolerance is implemented. But the limit is square root of 2 (1,41421356...). This value corresponds with the distance between points defined by this vectors.
Josh_Hunt
Thank you @Michael.Navara
That makes much more sense.
Josh Hunt
