Units Setting
Units Setting
Units Setting
I would like to display and setup all my Units to Feet and Fractional Inches. i would like to display everything in these units including the way parts are created from the content center example: 2'-1 1/2"  How do i change the default settings to this? I work in the structural steel industry
Thank you
HideoYamada
Hello Cadman2020,
I think there is no option to change unit settings at an application level, because every document has a unit settings.
This means the documents already existing must be changed one by one.
For the parts in content center, you can replace the template document in content center with the document you customized.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Inve...
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
