Unit Of Measure
Unit Of Measure
jpchaisson
Unit Of Measure
jpchaisson
im trying to draw a sketch line and when my code is ran it draws the line but in cm not inches. heres my code...
Dim oLines(0 To 3) AsSketchLine
oLines(0) = oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(0, 0), oTG.CreatePoint2d(0, 2))
when this runs i have a line thats 0.7874 inches, instead of 2 inches. how do i set the UOM so inventor knows i mean inches?
nmunro
All lengths in Inventor are stored internally as cm, all angles as radians. The UnitsOfMeasure object contains plenty of methods to do things like convert values between units. Check out the help file, it provides very good information and some samples.
https://c3mcad.com
jpchaisson
I have done that and tried many things but i get errors .
nmunro
Here is a generic example of how you might use one of the methods in the UnitsOfMeasure object to get what you are after.
' Get UOM object from the document with something like
Dim uom As UnitsOfMeasure
uom = <doc>.UnitsOfMeasure
' Get converted value (does not have to be done outside of AddByTwoPoints call, just for clarity sakes
Dim maxY As Double
' Convert 2" to cm (database length units)
maxY = uom.ConvertUnits(2.0, UnitsTypeEnum.kInchLengthUnits, UnitsTypeEnum.kDatabaseLengthUnits)
' Call the line creation method with the value converted to the required cm's
Dim oLines(0 To 3) As SketchLine
oLines(0) = oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(0, 0), oTG.CreatePoint2d(0, maxY))
Neil
https://c3mcad.com
