Unique view names?
Unique view names?
CadUser46
Unique view names?
CadUser46
Since it's possible for two views to have the same name, is there a better method to identify them in the API?
I'm trying to cross reference which balloons are attached to which views but not being able to identify them uniquely with a GUID or such is causing a problem.
Inventor 2010 Certified Professional
Currently using 2023 Pro
BrandonBG
Can you use DrawingViews.Item()? Then item numbers don't mean anything, but I believe all views are unique on a sheet. Beyond the sheet, I don't know how this would be useful.
Brandon
CadUser46
It;s an idea and i'll look into it but i'm not currently accessing the drawing views collection.  I think I'd still need to identify which ones are in the selectset against the collection using name.
HermJan.Otterman
you could add an attribute to each view...
then you'll have to write some code for every time you create a new view that an attribte is added with maybe the time or an other number
then you can use that attribute you ID the view...
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
CadUser46
Herman.  I'm not familiar with Attribute's.  Can you elaborate a bit further?
Are the attributes permanent or only have scope during runtime?  I only need to care when the macro is run so I guess I could iterate all the views on a sheet and add them each time.
HermJan.Otterman
Hello CadUser,
look at these sites:
http://modthemachine.typepad.com/my_weblog/2009/07/introduction-to-attributes.html
http://modthemachine.typepad.com/my_weblog/attributes/
Herm Jan
CadUser46
Thanks Herman.  I'd read this a long time ago but never connected the dots before now.
