Unfolded part & DXF export of Arc's issue (Inventor Pro 2022)
llorden4
llorden4
I'm using iLogic to Unfold a sheet metal part and then create a sketch to be used as a DXF export for CNC operations.  Everything is working well except for Arcs on the unfolded face.  They are arcs in the sketch, with a center point and have a Radius value if I place a driven dimension on the sketch.
Those arc's are being converted to LINES in the DXF.  I've confirmed this by exploding the shape and listed the object, which reports it in fact as a Line object.  The circle hole appears to be unaffected by this operation.
The arcs on the left side of this image are on the anchored face this is the locked face for the unfold operation.
This is bug or is there a solution for this issue?
Autodesk Inventor Certified Professional
llorden4
I just got a notification from my desktop app there is an update available.  Updated to 2022.1 and issue is resolved.
