Unexpected error While running iLogic Code
roelfoubert
roelfoubert
I get a unexpected error while running a iLogic rule in a big assembly.
Error on line 34 in rule: Quantity, in document: assembly.iam
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
   at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
   at Inventor.PropertySet.Add(Object PropValue, Object Name, Object PropId)
   at iLogic.CadPropertiesInRule.InvPropertyInSets(PropertySets propSets, String setName, String propName, Boolean createCustom)
   at iLogic.CadPropertiesInRule.InvProperty(Document doc, String setName, String propName, Boolean createCustom)
   at iLogic.CadPropertiesInRule.set_Value(Object compoOrDocName, String setName, String propName, Object value)
   at ThisRule.PurgeBatchQTY(Document oDoc) in external rule: Quantity:line 34
   at ThisRule.Main() in external rule: Quantity:line 21
   at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
This is the iLogic code I'm running:
Sub Main
    If ThisDoc.Document.DocumentType <> kAssemblyDocumentObject Then MsgBox("Rule can only run in assembly files!"): Exit Sub
    If ThisDoc.Document.FullFileName = "" Then MsgBox("Assembly not saved yet!" & vbLf & vbLf & "Aborting!"): Exit Sub
    Dim oGADoc As AssemblyDocument
    oGADoc = ThisDoc.Document
    BatchQTY = InputBox("ENTER TOTAL QTY OF ASSEMBLY", "ASSEMBLY QTY", "")
    iProperties.Value("Custom", "Aantal") = BatchQTY
    Dim oBOM As BOM
     oBOM = oGADoc.ComponentDefinition.BOM
    With oBOM
        .PartsOnlyViewEnabled = True
        .StructuredViewEnabled = True
        .StructuredViewFirstLevelOnly = False
    End With
    Call PurgeBatchQTY(oGADoc)
    Dim oBOMViewPO As BOMView = oBOM.BOMViews.Item("Parts Only")
    Call SetBatchPartQTYs(oBOMViewPO, BatchQTY)
    Dim oBOMViewStruc As BOMView = oBOM.BOMViews.Item("Structured")
    Call SetBatchAssemblyQTYs(oBOMViewStruc.BOMRows, BatchQTY)
End Sub
Sub PurgeBatchQTY(oDoc As Document)
    For Each oSubDoc In oDoc.AllReferencedDocuments
        If oSubDoc.IsModifiable = True Then
            iProperties.Value(System.IO.Path.GetFileName(oSubDoc.FullFileName), "Custom", "Aantal") = 0
    Next
End Sub
Sub SetBatchPartQTYs(ByVal oBOMViewPO As BOMView, ByVal BatchQTY As Integer)
    For Each oBOMRowPO In oBOMViewPO.BOMRows
        oCompDef = oBOMRowPO.ComponentDefinitions.Item(1)
        oRowDoc = oCompDef.Document
        Dim Qty As Integer = oBOMRowPO.TotalQuantity
        If oRowDoc.IsModifiable = True Then
            iProperties.Value(System.IO.Path.GetFileName(oRowDoc.FullFileName), "Custom", "Aantal") = Qty * BatchQTY
    Next
End Sub
Private Sub SetBatchAssemblyQTYs(oBOMRows As BOMRowsEnumerator, oParentQty As Integer)
    Dim oQty As Integer
    For Each oBOMRowStruct In oBOMRows
        oCompDef = oBOMRowStruct.ComponentDefinitions.Item(1)
        'Single line Check + Continues:
        If Not (TypeOf oCompDef Is AssemblyComponentDefinition And oCompDef.BOMStructure = BOMStructureEnum.kNormalBOMStructure) Then Continue For
        If oRowDoc.IsModifiable = False Then Continue For
        'Resume functionality
        oQty = oBOMRowStruct.ItemQuantity * oParentQty
        iProperties.Value(System.IO.Path.GetFileName(oRowDoc.FullFileName), "Custom", "Aantal") = oQty + iProperties.Value(System.IO.Path.GetFileName(oRowDoc.FullFileName), "Custom", "Aantal")
        If Not (oBOMRowStruct.ChildRows Is Nothing) Then
            Call SetBatchAssemblyQTYs(oBOMRowStruct.ChildRows, oQty)
    Next
End Sub
 The script works perfectly in small assemblies but has the error when I use it in a big assembly (+10000 occurrences)
Michael.Navara
It is hard to test your code if it works on small assemblies. But internally the code fails on
Which is Inventor API call for creating new iProperty.
You can rework the piece of code
to full Inventor API and log as much as possible when the exception raises (document, property name, property value, etc.).
'iProperties.Value(System.IO.Path.GetFileName(oRowDoc.FullFileName), "Custom", "Aantal") = Qty * BatchQTY
Dim oRowDoc As Document 'Defined above
Dim userDefinedPropertiesId As String = "{D5CDD505-2E9C-101B-9397-08002B2CF9AE}"
Dim propName As String = "Aantal"
Dim value As Object = Qty * BatchQTY 'Defined above
Dim qtyProp As Inventor.Property
Try
	qtyProp = oRowDoc.PropertySets(userDefinedPropertiesId)(propName)
	qtyProp.Value = value
Catch
	Try
		qtyProp = oRowDoc.PropertySets(userDefinedPropertiesId).Add(value, propName)
	Catch ex As Exception
		Logger.Error(ex.Message)
		Logger.Error(ex.ToString())
		Logger.Error(oRowDoc.DisplayName)
		Logger.Error(oRowDoc.FullFileName)
		Logger.Error(value)
	End Try
End Try
roelfoubert
I gives the same error at the same place.
Sub Main
    Dim oBOM As BOM
    With oBOM
    End With
End Sub
    Next
End Sub
Try
Catch
	Try
		Logger.Error(value)
	End Try
End Try
    Next
End Sub
    Dim oQty As Integer
    Next
End Sub
Michael.Navara
roelfoubert
Where can I find or see the log file?
