We have a separate sheet metal rule for every material and sheet thickness combination.
I see here and there that this is described as a good method.
In our sheet metal templates, material is listed as 'By Sheet Metal Rule'.
So far no problems until material is controlled via the BOM.
Then in fact a material override takes place with the possible consequence that different materials occur in a one part file which can sometimes be confusing, which one is meant?
I would like to know how I can use iLogic to undo the override and set it back to 'By Sheet Metal Rule'.
Are there perhaps better methods than described above.
I now use a rule 'Set Sheet Metal' from Luke Davenport to provide multiple parts of another sheet metal rule in an assembly.
Although the rule does its job well, nice piece of code by the way, we still prefer to be able to change the material from within the BOM.
How should we best set up the sheet metal rules in that case?
