underline text
underline text
GosponZ
underline text
GosponZ
I'm using this rule for years but need changed labels into underlined text. Would you guys help. I tried with
oViewLabel = "<StyleOverride Underline='True' </StyleOverride>" is not working
Accepted solutions (3)
WCrihfield
Hi @GosponZ.  I downloaded,  edited, then reattached the text file for you to try out.  I mainly just interupted the formatted string for the underlining, then included your 'LabelName' variable in the middle of it, where it should be, then continued the rest of it.  See if that works OK for you.  I would probably want to change "Pick a feature" to "Pick a drawing view" though. 😉
Wesley Crihfield
(Not an Autodesk Employee)
GosponZ
Hi ,
thank you so much it is working just perfect. I do have also another rule few weeks back i found here can't remember who make it but would like if you can very quick to take a look and ad underlined same as you did in previous.
WCrihfield
Sure.  Here you go.  (See attached.)
Wesley Crihfield
GosponZ
Thanks a lot
