Unable to run rules in parts within a component
865966724
865966724
Previously, I sought help and received an answer. Today, I have a new question. I am not good at programming, rules work well in certain aspects. When I put it into a component, it indicates a problem and I don't know how to modify it.😫
Dim oMeasureTools As MeasureTools = ThisApplication.MeasureTools
Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
Dim oPartCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
Dim oSurfaceBody As SurfaceBody = oPartCompDef.SurfaceBodies.Item(1)
Dim YZPlane As WorkPlane = oPartCompDef.WorkPlanes.Item("YZ Plane")
For Each oFace As Face In oSurfaceBody.Faces
    If oFace.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
        Dim FaceAngleRadians As Double = oMeasureTools.GetAngle(YZPlane, oFace)
        Dim FaceAngleDegrees As Double = FaceAngleRadians * 180 / Math.PI
        Dim FaceLocation As String
        If Not EqualWithinTolerance(FaceAngleDegrees, 90, 0.001) Then
            If oFace.PointOnFace.X > 0 Then
                FaceLocation = "Right"
				Parameter("R") =Round(FaceAngleDegrees, 2)
            Else
                FaceLocation = "Left"
				Parameter("L") =Round(FaceAngleDegrees, 2)
Next
WCrihfield
Hi @865966724.  I believe this is simply because Lines 2 & 3 are document type specific for a part only, not an assembly.  Try changing those 2 lines like this:
Dim oDoc As Document = ThisDoc.Document
Dim oCompDef As ComponentDefinition = oDoc.ComponentDefinition
Edit:  Actually, the term 'ThisApplication.ActiveDocument' is referencing the main assembly in that situation, instead of the part type component you are editing at the moment.  The equivalent way to reference the document being referenced by a component that you are in 'Edit Mode' for within an assembly would be 'ThisApplication.ActiveEditDocument'.
Wesley Crihfield
(Not an Autodesk Employee)
Thank you very much
