Unable to read all parameters with
I like to get all values of the parameters which are stored in an iLogic model. After collecting the values I like to generate all variants which are available with these parameters.
I have a strange problem with the function expressionlist.item()
Public Function getParamValues() As Collection
    Dim ParamName As String
    ParamName = "BOX1"
    Dim oParameters As Parameters
    Dim colParamValues As New Collection
    Dim intCount As Integer
    Set getParamValues = colParamValues
    Set oParameters = ThisApplication.ActiveDocument.ComponentDefinition.Parameters
    For intCount = 1 To oParameters.UserParameters.Item(ParamName).ExpressionList.Count
        colParamValues.Add oParameters.UserParameters.Item(ParamName).ExpressionList.Item(intCount)
    Next intCount
End Function
The part has a parameter "BOX1" which is a multi-value list. It contains the values "EDF1" "EDF2" and "EDF3".  The first element is always ???? after reading.
 The watch window shows the correct item() values. But colParamValues.Add recieves ????? values.
What am I overlooking here?
best regards,
Maarten Weers
Perker Hannifin b.v.
The Netherlands
MjDeck
  There is a problem with accessing ExpressionList items by index.  We should be able to get this fixed in a service pack for Inventor 2011.
 Here is a workaround, using another method to get the ExpressionList items:
    ParamName = "BOX1"
    Dim listValue As Variant
    For Each listValue In oParameters.UserParameters.Item(ParamName).ExpressionList
        colParamValues.Add listValue
    Next
End Function
    ParamName = "BOX1"
    Next
End Function
Mike Deck
Software Developer
Autodesk, Inc.
MjDeck
This is fixed in Inventor 2011 SP1, which is available at
 http://support.autodesk.com/getdoc.asp?id=DL15506670
Mike Deck
Software Developer
Autodesk, Inc.
