I am working on a vba form to change the 'vendor' field of a part. But I am unable to access the part's vendor propert unless I open the part in a new tab (window). If from an assembly, if I double click the part and run the rule, the vendor field of assembly is being modified. I'm sure there should be a slight modification of the following command to select the double clicked and opened part as the active file...
Dim invDoc As Document
Set invDoc = ThisApplication.ActiveDocument'Get the design tracking property set.
Dim invDesignInfo As PropertySet
Set invDesignInfo = invDoc.PropertySets.Item("Design Tracking Properties")
' Get the part number property.
Dim invPartNumberProperty As Property
Set invPartNumberProperty = invDesignInfo.Item("Vendor")
MsgBox invPartNumberProperty.Value 'Display the iproperty value
