Type of drawing dimmension
How can I check type of drawing dimmension
For example diameter or linear dimension?
Of course in VBA
Zorba29
Something like this I imagine:
[code]
Option Explicit
Private Sub CommandButton1_Click()
Dim oDimCon As DimensionConstraint
If TypeOf ThisApplication.ActiveDocument.SelectSet(1) Is DimensionConstraint Then
Set oDimCon = oSelectSet(1)
If oDimCon.Type = kRadiusDimConstraintObject Then
ElseIf oDimCon.Type = kDiameterDimConstraintObject Then
End Sub
[/code]
I think not exactly about it.
Drawing dimension are not sketched dimension.
I would like check type of drawing dimension
Your example work good only in sketch but it don't work on views of drawing.
How can I check type of dimensions on views of drawing
Einst_1
The ability to check for drawing dimension types was introduced in R11 and
is not available in previous releases. Here is some sample code. Select a
dimension and run the macro.
Sub DrawingDimensionType()
Dim oDim As DrawingDimension
Set oDim = ThisApplication.ActiveDocument.SelectSet.Item(1)
Select Case oDim.Type
Case kLinearGeneralDimensionObject
MsgBox "Linear general dimension"
Case kAngularGeneralDimensionObject
MsgBox "Angular general dimension"
Case kRadiusGeneralDimensionObject
MsgBox "Radius general dimension"
Case kDiameterGeneralDimensionObject
MsgBox "Diameter general dimension"
Case Else
MsgBox "Not a general dimension"
End Select
End Sub
Sanjay-
wrote in message news:5245482@discussion.autodesk.com...
Of course in VBA
Zorba29
Thank you very much.
Zorba29
