Type mismatch error
Type mismatch error
Type mismatch error
I am trying to create a circular pattern of a hole feature in an assembly with ilogic but i get a type mismatch error. Can anyone see what i am not seeing???
oDoc=ThisApplication.ActiveEditDocument
oHole= ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyFeatureFilter, "Select a hole feature")
oaxis = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllCircularEntities, "Select a hole circle edge")
Dim amount As Object = 4
Dim angle As Object = 360 * 180 / 3.14
circularPatternDef=oDoc.ComponentDefinition.Features.CircularPatternFeatures.CreateDefinition(oHole,oaxis,False,amount,angle,True)
Dim circularPat As CircularPatternFeature =oDoc.ComponentDefinition.Features.CircularPatternFeatures.AddByDefinition(circularPatternDef)
Sergio.D.Suárez
Hi, try with this code. There were some mistakes. For start the axis entity must be linear. On the other hand you have to specify a collection of objects to make the pattern in your case there is only one.
Dim objCol As ObjectCollection
objCol = ThisApplication.TransientObjects.CreateObjectCollection
objCol.Add(oHole)
oaxis = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllLinearEntities, "Select linear center edge")
'create pattern
Dim circularPat As CircularPatternFeature = oDoc.ComponentDefinition.Features.CircularPatternFeatures.Add(objCol, oaxis, False, amount, angle, True)
 I hope the code is useful for solving your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thanks for the code and fast reply
It creates a circular pattern with an error.
When i checked the health status of the circularfeature  i get this status:
kDriverLostHealth11780Object is driven by data from other Object(s), and one or more of them have been disconnected.
Is there a way to correct this error??
