Turning off object visibility - all working features and sketches in IAM and IPT
kmcga
Message 1 of 11
kmcga
Dear Community,
for some reason I need iLogic rule to turn off Object Visibility of Working Features, sketches and so on (see attachment).
I tried script from this link: https://forums.autodesk.com/t5/inventor-forum/automatically-turning-off-workfeatures/m-p/3816449#M46... but it doesn't work for me, some planes still remains after the rule execution.
I just need something that will umark exactly the checkboxes indicated in the attached screenshot, for parts and assemblies.
I am using Inventor 2021.3.
Could you support me in this issue?
Thank you in advance.
Krzysztof
Replies (10)
Message 2 of 11
JelteDeJong
There is no good way to do this but there is an ugly way. It is a problem that the rule can't detect if visibility is on or of. It will just toggle the settings. But if you have everything on then this script will toggle everything off (And on again if you run it a 2e time)
ThisApplication.CommandManager.ControlDefinitions.Item("AppAllWorkfeaturesCmd").Execute()
ThisApplication.CommandManager.ControlDefinitions.Item("AppConstructionSurfacesVisibilityCmd").Execute()
ThisApplication.CommandManager.ControlDefinitions.Item("AppSketchesVisibilityCmd").Execute()
ThisApplication.CommandManager.ControlDefinitions.Item("App3DSketchesVisibilityCmd").Execute()
ThisApplication.CommandManager.ControlDefinitions.Item("AppSketchDimensionsVisibilityCmd").Execute()
ThisApplication.CommandManager.ControlDefinitions.Item("App3DAnnotationsVisibilityCmd").Execute()
ThisApplication.CommandManager.ControlDefinitions.Item("App3DCompAnnotationsVisibilityCmd").Execute()
' Weld visability misbehaves so we need to execute it 2 times to make it toggle correct
ThisApplication.CommandManager.ControlDefinitions.Item("WeldmentSymbolsCmd").Execute()
ThisApplication.CommandManager.ControlDefinitions.Item("WeldmentGlobalVisibilityCmd").Execute()
Jelte de Jong
Blog: hjalte.nl - github.com
Message 3 of 11
kmcga
Thank you!
Message 4 of 11
JelteDeJong
Here is a better solution. (Credits to @engilic for finding these properties)
' https://help.autodesk.com/view/INVNTOR/2021/ENU/?guid=GUID-2386A49E-2B0C-41F5-9CC0-8FFB2A8CFF79
Dim doc As AssemblyDocument = ThisDoc.Document
Dim vis = doc.ObjectVisibility
If (vis.AllWorkFeatures) Then
    vis.AllWorkFeatures = False
    vis.ConstructionSurfaces = False
    vis.Sketches = False
    vis.Sketches3D = False
    vis.SketchDimensions = False
    vis.Annotations3D = False
    vis.ComponentAnnotations3D = False
    vis.Welds = False
    vis.WeldmentSymbols = False
Else
    vis.AllWorkFeatures = True
    vis.ConstructionSurfaces = True
    vis.Sketches = True
    vis.Sketches3D = True
    vis.SketchDimensions = True
    vis.Annotations3D = True
    vis.ComponentAnnotations3D = True
    vis.Welds = True
    vis.WeldmentSymbols = True
Jelte de Jong
Message 5 of 11
J.VandeMerckt
Hi!
Is it possible to get the original value of a workfeature state and use this later in the code?
I've tried this:
	'Get
	Dim oOriginalAllWorkfeatures As Boolean
	oOriginalAllWorkfeatures = oDoc.ObjectVisibility.AllWorkFeatures
	'Set original value
	oDoc.ObjectVisibility.AllWorkFeatures = oOriginalAllWorkfeatures
But it seems to give an error
Error on line 53 in rule: ThumbnailCreator, in document: Part2
Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
This is part of a larger code btw
Message 6 of 11
_dscholtes_
@J.VandeMerckt
Yes, that should be possible. I tested your code and it works for me.
I changed your code a little to get it running: I changed the 'oDoc' variable because it wasn't declared in your example, added the NOT in line 9 to force a change and check this change in the GUI / menus and added a few message boxes to see where it would crash, but it just worked.
'Get
oOriginalAllWorkfeatures = ThisDoc.Document.ObjectVisibility.AllWorkFeatures
MessageBox.Show(oOriginalAllWorkfeatures, "Title")
'Set original value
ThisDoc.Document.ObjectVisibility.AllWorkFeatures = Not  OriginalAllWorkfeatures
MessageBox.Show(ThisDoc.Document.ObjectVisibility.AllWorkFeatures, "Title")
Message 7 of 11
J.VandeMerckt
Yes my apologies, this code is part of a much bigger one.
I'll try to implement your adaption when I have some time.
I assume I will just need to remove the "not" on line 9 and it should work fine.
Thank you.
Message 8 of 11
_dscholtes_
I don't expect my changes will solve your issue as they did not essentially change the workings of the code.
Unless the ThisDoc.Document part solves it (then there's something unexpected in assinging oDoc), I expect the problem to be elsewhere in your code.
Message 9 of 11
J.VandeMerckt
In a class I declared oDoc As Document and in my Sub main oDoc = ThisApplication.ActiveDocument.
So not sure if it is maybe not possible in ThisApplication.ActiveDocument
I havn't found the time to test it yet.
Message 10 of 11
nathan_m_gardner
I can not get this to work on my parts. is this the full code? i am not a coder so I don't know what I am doing. thanks
Message 11 of 11
J.VandeMerckt
This is not full code.
You could try to use this snippet to turn AllWorkFeatures on or off with "True" or "False".
ThisDoc.Document.ObjectVisibility.AllWorkFeatures = False
I haven't tested it so I'm not sure if it works.
