Turn off Visibility of Part & Subassembly Sketches from Top Level
Zackery.Breeland
Zackery.Breeland
I have been fighting this for 2 days now trying to make a code that will turn off all work feature visibility for every part and subassembly from a top level assembly.  I am doing this because many older model I work with will open up with everything visible and it makes the model incredibly slow and I do not like turning off the sketch Object Visility through the View tab.
I have gotten working code for the work planes, axes and points, but the sketches are not working for me.  I have found a simple code to make sure it works in just the part level, posted below:
' Set a reference to the Sketches collection.  This assumes
    ' that a part document containing a sketch is active.
    Dim oSketches As PlanarSketches
    oSketches = ThisApplication.ActiveDocument.ComponentDefinition.Sketches
    ' Get whether the sketch visibility should be turned on or off.
    Dim bVisibleOn As Boolean
    If MsgBox("Do you want to turn all sketches on?", vbYesNo + vbQuestion) = vbYes Then
        bVisibleOn = True
    Else
        bVisibleOn = False
    ' Iterate through all of the sketches and set their visibility.
    Dim oSketch As PlanarSketch
    For Each oSketch In oSketches
        If bVisibleOn Then
            oSketch.Visible = True
        Else
            oSketch.Visible = False
    Next
    Dim partDef As PartComponentDefinition
    partDef = ThisApplication.ActiveDocument.ComponentDefinition
    Dim o3DSketches As Sketches3D
    o3DSketches = partDef.Sketches3D
    Dim oSketch3D As Sketch3D
    For Each oSketch3D In o3DSketches
        If bVisibleOn Then
            oSketch3D.Visible = True
        Else
            oSketch3D.Visible = False
    Next
And I simplified that to make it automatically turn off 2D sketches in a part:
Dim oPart As PartDocument = ThisApplication.ActiveDocument
    oSketches = oPart.ComponentDefinition.Sketches
    Next
But when I get to the assembly level code I am struggling.  I have managed to write up a small code while testing that will purse through the parts in an assembly, but I can't get it to affect the sketches:
Dim oAssyDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oAssyDef As AssemblyComponentDefinition = oAssyDoc.ComponentDefinition
Dim oDoc As Document
For Each oDoc In oAssyDoc.AllReferencedDocuments
	oDoc = ThisApplication.ActiveDocument
    Next
	'MsgBox("iterate")
Next
 I don't understand why you have to use the Document type in order to run through every part in an assembly, but then you can't reference ComponentDefinition.Sketches unless you're looking at a PartDocument type.  This is causing conflicts in how I'm setting this up.  I also tried setting this up as a Main and sub routine where the subroutine was simply the code I posted, that works on the part level, and the Main routine just runs through the parts, but I continued to get errors when trying to run it.
A.Acheson
You were almost there. Just needed to target the referenced document. You don't necessarily need to declare as a part/assembly document. If you know the syntax or refer to the help documents you can just write it generically to a document. Looking at the document under Derived Classes  you can go to Assembly/Part Document and find ComponentDefinition property under each.
For Each oDoc As Document In oAssyDoc.AllReferencedDocuments
	Dim oSketches As PlanarSketches = oDoc.ComponentDefinition.Sketches
    For Each oSketch As PlanarSketch In oSketches
    Next
Next
oAssyDoc.Update
Regards
Alan
Zackery.Breeland
Thank you for the links to the code reference library, I'm going through that now.  I took that code you modified and placed it into one of my sub-assemblies I'm testing in, and it ran but did not turn any of the sketches off.
A.Acheson
You may need to open the part file it is modifying to confirm it is working. If it is working in the part document and not in the assembly this will because of the design view rep of the assembly. Here you have the decision to link the view reps ( associative) meaning it follows the part document or use the assembly view rep which is an overwrite of the document view rep. In most case people keep the part document as Master. In my testing if the part sketch is made visible in the assembly it will break the link to the master view rep of the part. If you just try and relink the master view rep ( no associative is available) this refreshes the link. Ideally you would have a separate design view rep in the part and select associative. If all that fails this could then be a proxy sketch issue in the assembly.
Regards
Alan
Zackery.Breeland
You are absolutely right regarding the design view reps being out of sync and causing the issue.  I feel like I've burned so much time fighting this lol.  Thank you very much.
