Turn off flat pattern sketch
Curtis_Waguespack
Consultant Consultant
Message 1 of 1
Curtis_Waguespack
Quick example of turning flat pattern sketches on/off. Attached file is an Inventor 2024 file.
ShowSketch1 = InputRadioBox("Choose sketch to show", "Sketch 1", "Sketch2", booleanParam, Title := "iLogic")
'  a reference to the active document.
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
'verify document type is sheet metal
If oPartDoc.ComponentDefinition.Type <> 150995200 Then
	MessageBox.Show("File is not a sheet metal part.", "iLogic")
	Exit Sub
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
' Check to make sure a flat pattern is open.
If Not TypeOf ThisApplication.ActiveEditObject Is FlatPattern Then
	Try
		If oCompDef.HasFlatPattern = False Then
			oCompDef.Unfold
		Else
			oCompDef.FlatPattern.Edit
	Catch
		MessageBox.Show("Error editing the flat pattern.", "iLogic")
	End Try
'  a reference to the active flat pattern.
Dim oFlatPattern As FlatPattern
oFlatPattern = ThisApplication.ActiveEditObject
 oFlatPattern.Sketches.Item("FP Sketch1").Visible = ShowSketch1
 oFlatPattern.Sketches.Item("FP Sketch2").Visible = not ShowSketch1
Replies (0)
