turn off adaptivity using ilogic. leave reference
jskim00
jskim00
hello
I am using the below code to clear all adaptability of the assembly.
I want to know how to use it without clearing the reference as shown in the picture
Dim doc As Document = ThisApplication.ActiveDocument
For Each oDoc As Document In doc.AllReferencedDocuments
        Try
               If oDoc.ModelingSettings.AdaptivelyUsedInAssembly = True Then
                       oDoc.ModelingSettings.AdaptivelyUsedInAssembly = False
        Catch
        End Try
Next
WCrihfield
Hi @jskim00.  Would this iLogic code work OK for you?  I have not tested it yet myself, because I did not have any assembly examples (I can test on) with any adaptive components in them.
Dim oADoc As AssemblyDocument = ThisDoc.Document
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
Dim oOccs As ComponentOccurrences = oADef.Occurrences
Dim oOcc As ComponentOccurrence ' = oOccs.ItemByName("Part3:1")
For Each oOcc In oOccs
	If oOcc.Adaptive Then
		Try
			oOcc.Adaptive = False
		Catch
			Logger.Debug("Could not turn 'Adaptive' off for component named '" & oOcc.Name & "'.")
		End Try
Next
Wesley Crihfield
(Not an Autodesk Employee)
jskim00
Thank you! it works very well!
