Trying to use "GetPromptTextValues" method
dave_deane
Message 1 of 19
dave_deane
I am trying to display the Tags and Values of an inserted AutoCAD block in an Inventor 2013 dwg. I am using .Net studio10.
I can list the properties of the block object but cannot get the "GetPromptTextValues" method to work. Problem is at the bottom of the code listed below.
Dave
' Connect to a running instance of Inventor.
        Dim invApp As Inventor.Application
        ' Check to see if a drawing is active
        invApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        If invApp.ActiveDocument.DocumentType <> Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
            MsgBox("Need to have a drawing document active")
            Return
        ' Create ref to active drawing document
        Dim oDrawingDoc As Inventor.DrawingDocument
        oDrawingDoc = invApp.ActiveDocument
        ' Create ref to AutoCADBlocks collection in the active sheet
        Dim cAcadBlocks As Inventor.AutoCADBlocks
        cAcadBlocks = oDrawingDoc.ActiveSheet.AutoCADBlocks
        ' Get the name of the block
        Dim AcadBlockName As String
        AcadBlockName = cAcadBlocks.Item(1).Name
        Debug.Print(cAcadBlocks.Item(1).Name)
        ' Create ref to the AutoCAD block object in the active sheet
        Dim oAcadBlock As Inventor.AutoCADBlock
        oAcadBlock = cAcadBlocks.Item(AcadBlockName)
        ' check to see if block object code is working (it does)
        Debug.Print(oAcadBlock.Scale)
        Debug.Print(oAcadBlock.LineWeight)
        Debug.Print(oAcadBlock.Name)
        'XXXXXXXXXXXXXXXXXXXX FAILS BELOW XXXXXXXXXXXXXXXXXXXXX
        ' Try and display block tags and values
        Dim sTags(10) As String
        Dim sAttr(10) As String
        oAcadBlock.GetPromptTextValues(sTags, sAttr)
        ' display attribute tag and value
        For i = 0 To 10
            MsgBox(sTags(i) & " = " & sAttr(i))
        Next
Replies (18)
Message 2 of 19
Ralf_Krieg
Hello
This typically happens when your array has less (or more?) fields than your block attributes. Try
            Return
        Dim sTags() As String
        Dim sAttr() As String
        Dim iCount as integer
iCount = UBound(sTags)
' display attribute tag and value For i = 0 To sTags-1 MsgBox(sTags(i) & " = " & sAttr(i)) Next
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 3 of 19
dave_deane
Please see attached screen shot below
When looking at the object browser, it indicates the "GetPromptTextValues" method needs an Object and not a string.
So I used an object but I get an error message in Studio that... "it has been passed by reference befor being assigned a value". I thought thats what the "GetPromptTextValues" method did, pass a value?
The debugger says it needs a "NEW" keyword.... ?????
At my wits end trying to get this to work
Dave
Message 4 of 19
Ralf_Krieg
Hello
Take a second look, you're using GetPromptTextValues not GetPromptTags. Smiley Wink
Is there an error message using my suggestion?
R. Krieg
RKW Solutions
Message 5 of 19
dave_deane
Yes, the screen shot of the object browser was incorrect. Should have been the one in this attached screen shot. I also grabbed the error when using your suggestion.
Thanks for trying to help
Message 6 of 19
Ralf_Krieg
Hello
sTags and sValues are nothing, that's why the error occurs. You can prevent this, if you check both are not nothing after GetPromptTextValues and before you proceed.
Are you really sure your AutoCadBlock has attributes? Can you upload the Block to check this?
R. Krieg
RKW Solutions
Message 7 of 19
dave_deane
Hi again,
Yes the block has attributes and they are not empty. I have attached it.
I also added a document below with the code. you will need a button1 on a form1 to use it as is. Using studio 10 express here.
Message 8 of 19
Ralf_Krieg
Hello
Shame on me, there's a stupid error in my code. Please replace "sTags" with "iCount" in line
For i = 0 To sTags - 1
I tried it out with my code (don't have Studio 10) and it works.
R. Krieg
RKW Solutions
Message 9 of 19
Ralf_Krieg
Once again
Seem's there is a difference between using this code in VBA and VB. If the arrays are defined without fixed size, nothing is result. Forget my last post and try this:
Public Class Form1
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
            Return
        ' Set the name of the block
        AcadBlockName = "BRA"
        Debug.Print(oAcadBlock.AttributeSets.Count)
        Dim i As Integer
        Dim iCount As Integer
        Debug.Print("icount = " & iCount)
        For i = 0 To iCount
            i = i + 1
        Next
    End Sub
End Class
R. Krieg
RKW Solutions
Message 10 of 19
dave_deane
Krieg,
I really appreciate your continued assistance. Unfortunately, I am still unable to get to the tags and values. I created a screen recording with audio showing the error using strings and objects. Hope this helps to explain things, turn up the volume and enjoy the show.
http://screencast.com/t/9DRBWW4MS
Dave
Message 11 of 19
Ralf_Krieg
Hello
I see the video, but can't believe what I see. I'm using the same code (with removed i=i+1, that's correct in your code), open a new Inventor-dwg, insert block "BRA" from your template file, fill out some attributes, run the code and get attributes and values. Please see attached Screenshots in zipfile.
I'm using Inventor 2013 SP1.1 Update 1.
Sorry, I'm running out of ideas what's going wrong.
R. Krieg
RKW Solutions
Message 12 of 19
dave_deane
I am using Inventor Professional 2013 sp1.1 64 bit xp pro
I also have Inventor 2013 sp1.1 (non professional) on 32 bit xp pro. It doesn't work on either.
In your code did you have sTags dim as strings or objects? Any chance you can upload the .exe to see if your working build works on this end?
A support case has been logged at Autodesk. Hopefully, I will get this sorted out.
Thank you again,
Dave
Message 13 of 19
Ralf_Krieg
Hello
sTags and sValues are defined as String. I have counted the attributes and found 23. So:
Dim sTags(23) As String
Dim sAttr(23) As String
 I attached the exe and if this works on your site, I can send you my project. Maybe there's a difference we both don't registred yet.
Please replace the extension txt with exe.
R. Krieg
RKW Solutions
Message 14 of 19
dave_deane
It doesn't work. I get an array error, screenshot below.
I hope autodesk support can save me on this one. I don't know what else to do.
Message 15 of 19
Ralf_Krieg
Hello
Sorry couldn't help you. My best wishes Autodesk can help.
R. Krieg
RKW Solutions
Message 16 of 19
xiaodong_liang
Autodesk Support
Autodesk Support
I discussed with our engineer and we did some tests. The following code can work. Not much change than the code Krieg provided in message 9. Could you give it a try?
  PrivateSub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
            Return
        EndIf
        Dim AcadBlockName AsString
        'correct
        Dim sTags() AsString = NewString() {}
        Dim sAttr() AsString = NewString() {}
        'wrong
        'Dim sTags() As String = New Object() {}
        'Dim sAttr() As String = New Object() {}
        'correct only when  the count of texts
        ' are no more than 23
        'Dim sTags(23) As String
        'Dim sAttr(23) As String
        'wrong
        Dim i AsInteger
        Dim iCount AsInteger
        For i = 0 To iCount
            i = i + 1
        Next
    EndSub
Message 17 of 19
dave_deane
Xiaodong,
It will not build as posted. Intellisense does not like AsString, Once I separate the words it then doesn't like the empty squiggly brackets at the end. Please see screen shot below.
Message 18 of 19
Ralf_Krieg
Hello
Try it in this way
Dim sTags() As String = New System.String() {}
R. Krieg
RKW Solutions
Message 19 of 19
dave_deane
Winner, Winner! ....... It builds and works! Thank you Krieg and Xiadong.
Is this just part of the learning curve or is there some reading references I need to study? I'm not sure how I would have ever figured this out. I can't find any meaningful syntax explantion searching the web for this. What purpose does the "{}" do? I'm just wondering out loud why a "regular" string array does not work for me but it did for you Krieg?
Onward with the rest of my program development.
Thank you again,
Dave
