Try to scale a Image in a Sketch
mecanicu
mecanicu
Hello!
I'm try to scale a image that i imported throw insert image command. But I don't know how to scale it. The scale factor need's to be 1.35.
Here is the code i have:
Sub Main()
    ' ***Change path to point to the desired bmp file.
    Dim strImagePath As String
    strImagePath = "C:\Temp\1.jpg"
    ' Create a new part document, using the default part template.
    Dim oPartDoc As PartDocument
     oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
                ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
    ' Set a reference to the component definition.
    Dim oCompDef As PartComponentDefinition
     oCompDef = oPartDoc.ComponentDefinition
    ' Create a new sketch on the X-Y work plane.
    Dim oDecalSketch As PlanarSketch
    oDecalSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(3))
    ' Set a reference to the transient geometry object.
    Dim oTransGeom As TransientGeometry
     oTransGeom = ThisApplication.TransientGeometry
    Dim oCenter As Point2d
     oCenter = oTransGeom.CreatePoint2d(0, 0)
    ' Add a sketch image
    Dim oSketchImage As SketchImage
     oSketchImage = oDecalSketch.SketchImages.Add(strImagePath, oCenter)
	' Edit sketch
	oDecalSketch.Edit
	' Try set image Height & Width (better a scale factor)
	Dim iHeight As Double
     iHeight = oSketchImage.Height
	  iHeight = 10
	Dim iWidth As Double
     iWidth = oSketchImage.Width
	  iWidth = 20
End Sub
mecanicu
Nvm.
I resolve the problem. 🤦‍♂️
Sub Main()
	' Edit sketch
	oDecalSketch.Edit
	oSketchImage.Height = 30
End Sub
