Troubles with Add-In creating. Cannot load Microsoft.Net.CoreRuntime.ImportBefore.targets, lack off Microsoft.Common.CurrentVersion.targets
MaciejWojda
MaciejWojda
Hi everyone,
I have abovementioned problem with creating add-in to Inventor 2022 in Visual Studio 2019. I have installed developertools from SDK.
When I try to configure new project, the error occures which says that:
1. Cannot load imported project file "C:\Program Files (x 86)\Microsoft Visual Studio\2019\Community\MSBuild\Current\Microsoft.Common.Targets\ImportBefore\Microsoft.Net.CoreRuntime.ImportBefore.targets"
2. Lack of main element. C:\Program Files (x 86)\Microsoft Visual Studio\2019\Community\MSBuild\Current\Bin\Microsoft.Common.CurrentVersion.targets
The files Microsoft.Net.CoreRuntime.ImportBefore.targets and Microsoft.Common.CurrentVersion.targets exist at the paths.
I cannot resolve this problem and go further, please help
Best regards,
Maciej Wojda
n_Sovljanski
I didn't have any problems with creating blank project. If you are in hurry you can download project that I created from github
https://github.com/Nendzi/InventorAddIninVB
and maybe later you find out what was problem.
MaciejWojda
Thank you @n_Sovljanski for your piece of code.
I don't know exactly what caused my problem, but it looks like some residues after Visual Studio 2022, which I had installed as first IDE on the Win10 system. Then I realized, that SDK for inventor does not support VS 2022 yet and it supports 2019 version. I installed VS 2019 and then installation of SDK also finally succeeded. Nevertheless sample could not work with problems described in this topic. I deinstalled VS 2022, but problem did not disappeare.
The next step was to install VS 2019, Inventor and SDK on fresh Win10 system and finally worked.
If someone in the future will find some more exact solution than starting from scratch, please share it here.
Have a nice day!
n_Sovljanski
I am glad that you have success. Also pay attention that Inventor addin use NET 4.8 Framework. You can not use NET Core in your projects. VS2022 use NET Core as default platform, you can change it but - you must do it.
MaciejWojda
By the way, maybe you know how to make professional installer for Inventor addin? I tried but with no luck so far. I can't even find helpful knowledge on the Internet
