Troubles creating a Sweep feature with an ilogic rule.Troubles creating a Sweep feature with an ilogic rule.
camilo.ariasHKTWD
camilo.ariasHKTWD
Any suggestion with this issue?
Please help me with this trouble.
Michael.Navara
Please if you put the code to the post use </> button to insert code snippet. Don't post code as image.
If you can upload the sample part, it can be helpful.
camilo.ariasHKTWD
Please an apologies but I'm new in this community.
Of course I can put the rule code.
It's in the text file called "Code file.txt"
Michael.Navara
Be careful which parameters you use
I just change first argument of CreateSweepDefinition to SweepTypeEnum.kPathSweepType
Dim oApp As Inventor.Application
oApp = ThisApplication
' Obtener el documento activo (debe ser un ensamblaje o un archivo de pieza)
Dim oDoc As Inventor.PartDocument
oDoc = oApp.ActiveDocument
Dim oCompDef As Inventor.PartComponentDefinition
oCompDef = oDoc.ComponentDefinition
If Hubo_Error_Short = 1 Then
    Try
        Dim ShortStay As Inventor.SweepFeature
        Dim staydef As Inventor.SweepDefinition
        Dim oprof As Inventor.Profile
        Dim opath As Inventor.Path
        oprof = oCompDef.Sketches.Item("Short_Profile").Profiles.AddForSolid()
        opath = oCompDef.Features.CreatePath(oCompDef.Sketches.Item("Short_Path").SketchLines.Item(4 - 3))
        staydef = oCompDef.Features.SweepFeatures.CreateSweepDefinition(
            SweepTypeEnum.kPathSweepType,
            oprof,
            opath,
            PartFeatureOperationEnum.kJoinOperation
        ShortStay = oCompDef.Features.SweepFeatures.Add(staydef)
    Catch ex As Exception
        ' Manejar cualquier error que pueda ocurrir durante la operación de barrido
        MsgBox("Error al realizar la operación de barrido: " & ex.Message)
    End Try
