TRIMSOLID Error With VBA
Olsndot
Olsndot
Hi,All.
I'm trying to trim SolidBody with SurfaceBody, but an error occurs.
In the case of using WorkSurface ,this code works.
Whats wrong with this code?
Sub Trim_Solid()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As PartComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Dim oFace As Face
    Set oFace = ThisApplication.CommandManager.Pick _
    (SelectionFilterEnum.kAllEntitiesFilter, "Select a surface")
    Dim oSBody As SurfaceBody
    Set oSBody = oFace.Parent
    Dim oSplitFeature As SplitFeature
    Set oSplitFeature = oDef.Features.SplitFeatures.TrimSolid(oSBody, oDef.SurfaceBodies.Item(1), True)
End Sub
Sergio.D.Suárez
Hi, try this code maybe I can serve you.
Sub Trim_Solid()
    Dim oFace As Face
        (SelectionFilterEnum.kPartFaceFilter, "Select a surface")
    Dim oWS As WorkSurface
    For Each oWS In oDef.WorkSurfaces
        If oWS.SurfaceBodies(1).Name = oFace.SurfaceBody.Name Then
            Set oSplitFeature = oDef.Features.SplitFeatures.SplitBody(oWS, oDef.SurfaceBodies.Item(1))
    Next
End Sub
I hope this helps. Grettings!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Olsndot
Thank you,Sergio.
I had no idea there is such a way!
I appreciate your help!
