Trim solid with a plane using VBA
danijel.radenkovic
danijel.radenkovic
Hello to all,
I am wondering if there is a possibility to split (trim solid) using VBA.
I have found a code for surface splitting but not for solid:
Dim spFeature As SplitFeature
Set spFeature = oPrtFeats.SplitFeatures.TrimSolid(oSelectedTool, oSelectedOcc.Definition.SurfaceBodies(1), ),False)
 Regards
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
Jef_E
You might be surprised to know that the surfacebodies collection is a collection of solids.
You can put this to the test, create a part with multiple solids and run this rule in iLogic and it will show all the names for your solids.
Maybe the name is a bit confusing 😄
Dim oInvApp As Application
oInvApp = ThisApplication
Dim oDoc As PartDocument
oDoc = oInvApp.ActiveDocument
Dim oDef As PartComponentDefinition
oDef = oDoc.ComponentDefinition
For Each oSurfaceBody As SurfaceBody In oDef.SurfaceBodies
	MsgBox(oSurfaceBody.Name)
Next
*note that this code will only work for part documents!
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
danijel.radenkovic
Hi Jef,
I am suprised with the name "SurfaceBodies" for collection of Solid Bodies.
I have tried what you suggested and iLogic gave me the names of solids in multibody part, as you said.
So in my case, if I want to trim solid with a plane, this should looks like:
Dim oPartFeatures As PartFeatures
Set oPartFeatures = oPartDoc.ComponentDefinition.Features
Dim oSplit As SplitFeature
Set oSplit = oPartFeatures.SplitFeatures.TrimSolid(oRefPlane, oPartDef.SurfaceBodies(1), False)
Thank you, Jef!
Danijel
danijel.radenkovic
I have one more doubt.
Let's say that I decided to create split part using Plane1. How to edit the same split feature using Plane2?
I am not looking to delete feature and create a new one but to edit split feature.
I tried with:
Set oSplit = oPartFeatures.SplitFeatures.TrimSolid(oPlane2, oPartDef.SurfaceBodies(1), True)
But it creates new split feature so I have two of them.
Danijel
Jef_E
Well thats because you are adding a feature, when you refer to the existing the split you are able to edit it.
        Dim oSplitFeature As SplitFeature
        oSplitFeature = oDef.Features.SplitFeatures.Item(1)
        oSplitFeature.SetToTrimSolid(oDef.WorkPlanes.Item(2), oDef.SurfaceBodies.Item(1), True)
Sorry for the late response, I intended to reply yesterday but apparently I did not hit sent.
Inventor 2014 SP2
danijel.radenkovic
There is something wrong with the last line of the code:
Also, would you like to explain me why sometimes I must to add "Set" to define some feature cause it says as on the image bellow , but sometimes works without adding "set"?
Regards
Danijel
danijel.radenkovic
Regards
Danijel
Solved. I forgot to call update of the feature.
Call oSplitFeature.SetToTrimSolid(oDef.WorkPlanes.Item(2), oDef.SurfaceBodies.Item(1), True)
Regards
Danijel
