Trigger Rule When Placing Component in Assembly
bhudson4XNR5
bhudson4XNR5
Hi All,
I have a rule in an assembly template that I want to run any time a new component is placed in that assembly. I'm looking for a way to trigger that rule, but it doesn't look like there is anything under the event triggers that would apply to this.  Any thoughts on a way to accomplish this?
Thanks!
JelteDeJong
I think your best option is to create an addin and watch for the event.
Inventor.Application.ApplicationEvents.OnDocumentChange
Jelte de Jong
Blog: hjalte.nl - github.com
bhudson4XNR5
I've been working to solve this and thought I had it but have run into an issue.
The goal of all this is that when this specific assembly document type is opened, it waits for a new occurrence, and runs the rule "Material AutoFill".  "Material AutoFill" will take the last part occurrence and place that part's name into a custom iProperty of the current assembly file.
I created an internal rule inside the specific template called "event trigger" using handlers.  This rule triggers on a new document or open document, so anytime a new or existing assembly of this type is created/opened the handler runs.
The "event trigger" code is below:
Sub Main
	Dim oAsmEvents As AssemblyEvents = ThisApplication.AssemblyEvents
	AddHandler oAsmEvents.OnNewOccurrence, AddressOf oAsmEvents_OnNewOccurrence
	Dim oAppEvents As ApplicationEvents = ThisApplication.ApplicationEvents
	AddHandler oAppEvents.OnCloseDocument, AddressOf ApplicationEvents_OnCloseDocument
End Sub
Public Sub oAsmEvents_OnNewOccurrence(oAsmDoc As AssemblyDocument, oOcc As ComponentOccurrence, oTiming As Inventor.EventTimingEnum, oContext As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum)
	If oTiming = kAfter Then
		iLogicVb.RunRule("Material AutoFill")
End Sub
Public Sub ApplicationEvents_OnCloseDocument(oDoc As Inventor._Document, oFullName As String, oTiming As Inventor.EventTimingEnum, oContext As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum)
	If oDoc Is ThisDoc.Document Then
		RemoveHandler oAsmEvents.OnNewOccurrence, AddressOf oAsmEvents_OnNewOccurrence
		RemoveHandler oAppEvents.OnCloseDocument, AddressOf ApplicationEvents_OnCloseDocument
End Sub
The autofill rule is a separate internal rule that looks through all occurrences, and takes the last one and places it into the custom iProperty field.
The "Material AutoFill" code:
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
    Dim oName As String
    oName = Left(oOccurrence.Name, 9)
    iProperties.Value("Custom", "Material2") = oName
Next
This has worked exactly as I wanted until I started working in higher level assemblies.  If I open a higher level assembly that contains one of the assemblies with these rules, the handler will run and any new occurrences in the higher level assembly will trigger the rules.  The higher level assembly in these cases does not contain either of the rules above.
I only want the rules to trigger when that specific document is worked on, and only when that specific document sees a new occurrence.
Any thoughts on how to address this?
