Triangular Fold Line Notching
MattyB92
MattyB92
I have a specific problem, I for the life of me can not figure out this issue.
I have used a code from this forum for automating the notching, however it is in the wrong orientation. See attached pictures.
I would like 1 of the peaks of the triangle notches to align with the bend lines.
These are incorrect done by the iLogic automation code:
As an example here is a manual one I have done:
Code as attached:
Sub Main
	'[ edit these variables as needed
	sSketchName = "Flat Pattern Sketch"
	sCutName = "Triangles"
	'  a reference to the active document.
	Dim oPartDoc As PartDocument
	oPartDoc = ThisApplication.ActiveDocument
	'verify document type is sheet metal
	If oPartDoc.ComponentDefinition.Type <> 150995200 Then
		MessageBox.Show("File is not a sheet metal part.", "iLogic")
		Exit Sub
	Dim oCompDef As SheetMetalComponentDefinition
	oCompDef = oPartDoc.ComponentDefinition
	' Check to make sure a flat pattern is open.
	If Not TypeOf ThisApplication.ActiveEditObject Is FlatPattern Then
		Try
			If oCompDef.HasFlatPattern = False Then
				oCompDef.Unfold
			Else
				oCompDef.FlatPattern.Edit
		Catch
			MessageBox.Show("Error editting the flat pattern.", "iLogic")
		End Try
	'  a reference to the active flat pattern.
	Dim oFlatPattern As FlatPattern
	oFlatPattern = ThisApplication.ActiveEditObject
	'clean up existing holes
	Dim oCut As ExtrudeFeature
	For Each oCut In oFlatPattern.Features.ExtrudeFeatures
		oCut.Delete
	Next
	Dim oFace As Face
	oFace = oFlatPattern.TopFace
	Dim oSketch As PlanarSketch
	'clean up existing sketch
	For Each oSketch In oFlatPattern.Sketches
		If oSketch.Name = sSketchName Then
			oSketch.Delete
	Next
	' Create a new sketch.
	' the Second argument specifies To include/Not include
	' the edges of the face in the sketch.
	oSketch = oFlatPattern.Sketches.Add(oFace, False)
	' Change the name.
	Dim oEdges As Edges
	' Create a new object collection for the hole center points.
	oHoleCenters = ThisApplication.TransientObjects.CreateObjectCollection
	' Get all Bend UP edges
	'where true = top face
	oEdges = _
	oFlatPattern.GetEdgesOfType( _
	FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge, True)
	'process the Bend Edges
	Call CreateSketch(oSketch, oEdges)
	' Get all Bend Down edges
	oEdges = _
	FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge, True)
	Dim oProfile As Profile
	oProfile = oSketch.Profiles.AddForSolid
	' Create an extrusion
	Dim oExtrude As ExtrudeFeature
	oExtrude = oFlatPattern.Features.ExtrudeFeatures.AddByThroughAllExtent(oProfile, kSymmetricExtentDirection, kCutOperation)
	oExtrude.Name = sCutName
	'oCompDef.FlatPattern.ExitEdit
	'	oPartDoc.Save
End Sub
Sub CreateSketch _
	(oSketch As Sketch, oEdges As Edges)
	Dim oUOM As UnitsOfMeasure
	oUOM = ThisDoc.Document.UnitsOfMeasure
	oLenUnits = oUOM.GetStringFromType(UnitsTypeEnum.kDefaultDisplayLengthUnits)
	oInvUnits = UnitsTypeEnum.kCentimeterLengthUnits
	oInvUnitString = oUOM.GetStringFromType(oInvUnits)
	oConversion = oUOM.ConvertUnits(1, oUOM.LengthUnits, oInvUnits)
	' Set a reference to the transient geometry object.
	Dim oTransGeom As TransientGeometry
	oTransGeom = ThisApplication.TransientGeometry
	For Each oEdge In oEdges
		'create line
		Dim skLine As SketchLine
		skLine = oSketch.AddByProjectingEntity(oEdge)
		Dim oLineSegment1 As LineSegment2d
		oLineSegment1 = skLine.Geometry
		Dim startPt As Point2d
		startPt = skLine.StartSketchPoint.Geometry
		Dim endPt As Point2d
		endPt = skLine.EndSketchPoint.Geometry
		Dim oInterSectPoint As Point2d
		'create triangle
		Dim oBotDia As Double = .144 * oConversion
		For i = 1 To 2
			Dim oPolygon As SketchEntitiesEnumerator
			oPolygon = oSketch.SketchLines.AddAsPolygon(3, endPt, startPt, True)
			Dim oCircle As SketchCircle
			oCircle = oSketch.SketchCircles.AddByCenterRadius(endPt, oBotDia)
			oCircle.Construction = True
			oDim = oSketch.DimensionConstraints.AddDiameter(oCircle, endPt)
			'Constrain Circle tangent to Lines of Polygon
			oSketch.GeometricConstraints.AddTangent(oPolygon.Item(1), oCircle)
			oSketch.GeometricConstraints.AddTangent(oPolygon.Item(2), oCircle)
			oSketch.GeometricConstraints.AddTangent(oPolygon.Item(3), oCircle)
			If i = 1 Then
				oSketch.GeometricConstraints.AddCoincident(skLine.StartSketchPoint, oCircle.CenterSketchPoint)
				oSketch.GeometricConstraints.AddHorizontal(oPolygon.Item(2))
			Else
				oSketch.GeometricConstraints.AddCoincident(skLine.EndSketchPoint, oCircle.CenterSketchPoint)
				oSketch.GeometricConstraints.AddHorizontal(oPolygon.Item(1))
		Next
	Next
End Sub
BM_Ashraf
Hi is it possible to share the test file. To find the exact Problem.
I think the Problem cound be because of the  Geomtic Constrains
Sub Main
		Exit Sub
		Try
				oCompDef.Unfold
			Else
		Catch
		End Try
		oCut.Delete
	Next
	Dim oFace As Face
			oSketch.Delete
	Next
	' Change the name.
	Dim oEdges As Edges
	oEdges = _
	oEdges = _
	'	oPartDoc.Save
End Sub
Sub CreateSketch _
		'create line
		'create triangle
		For i = 1 To 2
			If i = 1 Then
				'oSketch.GeometricConstraints.AddHorizontal(oPolygon.Item(2))
				oSketch.GeometricConstraints.AddPerpendicular(oPolygon.Item(2),skLine)
			Else
				'oSketch.GeometricConstraints.AddHorizontal(oPolygon.Item(1))
				oSketch.GeometricConstraints.AddPerpendicular(oPolygon.Item(1),skLine)
		Next
	Next
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Blue Mech
Add-ins for Inventor!
MattyB92
See attached 🙂
J-Camper
Instead of making a line Horizontal, I would coincident one of your polygon points to the edge's SketchLine.  You can then validate it is in the correct direction, and move the point if needed.  Try replacing your "CreateSketch" Sub with this:
Sub CreateSketch (oSketch As PlanarSketch, oEdges As Edges)
	Dim SketchFace As Face = TryCast(oSketch.PlanarEntity, Face)
	If SketchFace Is Nothing Then MessageBox.Show("Sketch Not created on face.") : Exit Sub
		'create line
		Dim skLine As SketchLine = oSketch.AddByProjectingEntity(oEdge)
		Call AddTriangleToLinePoint(SketchFace, oBotDia, skLine, "Start")
		Call AddTriangleToLinePoint(SketchFace, oBotDia, skLine, "End")
	Next
End Sub
Sub AddTriangleToLinePoint(TestFace As Face, CircleDiameter As Double, skLine As SketchLine, PointSelection As String)
	Dim TargetPoint As SketchPoint
	Dim TempPoint As SketchPoint
	Select Case PointSelection
	Case "Start"
		TargetPoint = skLine.StartSketchPoint
		TempPoint = skLine.EndSketchPoint
	Case "End"
		TargetPoint = skLine.EndSketchPoint
		TempPoint = skLine.StartSketchPoint
	Case Else
		MessageBox.Show("Can only add triangle to ""Start"" or ""End"" point of SketchLine")
		Exit Sub
	End Select
	Dim oSketch As PlanarSketch = skLine.Parent
	Dim oPolygon As SketchEntitiesEnumerator = oSketch.SketchLines.AddAsPolygon(3, TargetPoint.Geometry, TempPoint.Geometry, True)
	Dim oCircle As SketchCircle = oSketch.SketchCircles.AddByCenterRadius(TargetPoint.Geometry, CircleDiameter)
	oSketch.DimensionConstraints.AddDiameter(oCircle, TargetPoint.Geometry)
	oSketch.GeometricConstraints.AddCoincident(TargetPoint, oCircle.CenterSketchPoint)
	'Constrian polygon to line
	Dim coincidentPoint As SketchPoint = oPolygon.Item(1).StartSketchPoint
	oSketch.GeometricConstraints.AddCoincident(skLine, coincidentPoint)
	'Adjust coincident point if not on face
	Dim TestPoint As Point = TestFace.GetClosestPointTo(coincidentPoint.Geometry3d)
	Dim AdjustmentVector As Vector2d = Nothing
	If Round(TestPoint.DistanceTo(coincidentPoint.Geometry3d), 9) <> 0
		AdjustmentVector = coincidentPoint.Geometry.VectorTo(oCircle.CenterSketchPoint.Geometry)
		AdjustmentVector.ScaleBy(2)
		coincidentPoint.MoveBy(AdjustmentVector)
End Sub
Let me know if you have any questions, or if this is not working as intended
MattyB92
That worked fantastically, thank you so much.
They are now in the correct orientation 🙂
