Traverse an Assembly Using Custom Job - Inventor Server
con_smith
Message 1 of 1
con_smith
Perhaps an easy one, but I am struggling to find documentation on how to use Inventor Server instead of Apprentice. I am trying to use apprentice to traverse and assembly, but it just is not working. I receive COMException when trying to call occurrences.Name;
string mDocPath = AcquireFileForInventorAndGetPath(connection, mWsMgr, selectedContextFile);
ApprenticeServerComponent apprenticeServer = new ApprenticeServerComponent();
ApprenticeServerDocument apprenticeDocument = apprenticeServer.Open(mDocPath);
IterateBOM(apprenticeDocument.ComponentDefinition.Occurrences, connection, mWsMgr, BOM, bomLevel, parentName);
 public static ErrorHandler IterateBOM(ComponentOccurrences asssemblyOccurrences, Connection connection, WebServiceManager mWsMgr, Dictionary<string, BomItem> BOM, int bomLevel, string parentName)
     bomLevel++;
     foreach (ComponentOccurrence occurrence in asssemblyOccurrences)
         string occurrenceNameForError = occurrence.Name;
         try
             if (!occurrence.Suppressed)
                 UpdateBomDictionary(occurrence, BOM, bomLevel, parentName, "Assembly");
                 string newParentName = occurrence.Name;
                 MessageBox.Show(newParentName, "Message", MessageBoxButtons.OK);
                 ProcessAllSubOcc(occurrence.SubOccurrences, connection, mWsMgr, BOM, bomLevel, newParentName);
         catch (Exception ex)
             ErrorHandler iterateBOMError = new ErrorHandler() { FailureOccurred = true, Message = $"{ex.ToString()} --- Document {occurrenceNameForError} has caused a failure." };
             return iterateBOMError;
     ErrorHandler iterateBOMSuccess = new ErrorHandler() { FailureOccurred = false, Message = "Success" };
     return iterateBOMSuccess;
        public static void ProcessAllSubOcc(ComponentOccurrencesEnumerator subOccurrences, Connection connection, WebServiceManager mWsMgr, Dictionary<string, BomItem> BOM, int bomLevel, string parentName)
            bomLevel++;
            foreach (ComponentOccurrence occurrence in subOccurrences)
        public static void UpdateBomDictionary(ComponentOccurrence occurrence, Dictionary<string, BomItem> BOM, int bomLevel, string parentName, string documentType)
            //string occurrencePath = occurrence.ReferencedDocumentDescriptor.FullDocumentName;
            //string[] filePathParts = occurrencePath.Split(new char[] { '\\', '/' }, StringSplitOptions.RemoveEmptyEntries);
            //string occurrenceName = filePathParts[filePathParts.Length - 1];
            string occurrenceName = occurrence.Name;
            if (BOM.ContainsKey(occurrenceName) == false)
                BomItem newItem = new BomItem();
                newItem.FullFileName = occurrenceName;
                newItem.Quantity = 1;
                newItem.BOMLevel = bomLevel;
                newItem.BOMParent = parentName;
                //newItem.AssemblyOrPart = documentType;
                BOM.Add(occurrenceName, newItem);
            else
                BOM[occurrenceName].Quantity += 1;
I have seen others do this successfully using Inventor, but I am struggling to find how to instantiate a session of Inventor similar to how I do above with Apprentice. Any tips or links?
Replies (0)
