Transform 2D global XY coordinates to local XY coordinates
william
william
Hello
Some context to this issue.
I was having issues with the built in command below to export face to DXF.
ThisApplication.CommandManager.ControlDefinitions.Item("GeomToDXFCommand")
 There is no way to specify the export version (See related posts on this below). This meant that the exported dxf would export with splines and would fail on import by other programs requiring the splines to be linearized.
iLogic/API: Provide an API for exporting a face to DXF (with options) - Autodesk Community
Setting the ACAD Version for Export Surface from Part to dxf File with the API - Autodesk Community
So, I have this rule that creates a dxf file from a selected face. It linearizes all the edges on a face and writes to a dxf file.
The problem I have is that it only works on horizontal faces, because the XY coordinates of the edge vertices are global and not transformed to the normal of the face selected.
How would I transform these points to give me the local XY coordinates from the face selected?
Sub Main()
Dim oDoc As PartDocument = ThisDoc.Document
Dim oCompDef = oDoc.ComponentDefinition
Dim entity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a Face")
oDoc.SelectSet.Select(entity)
Dim oFace As Face
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oPointCol As New List(Of Double())
Try
    oFace = ThisApplication.ActiveDocument.SelectSet.Item(1)
Catch
    MsgBox("A face must be selected.")
End Try
oDoc.SelectSet.Clear
'Dim oSketch As PlanarSketch
'oSketch = oCompDef.Sketches.Add(oFace)
'oSketch.OriginPoint = oCompDef.WorkPoints.Item(1)
' Create a new file
Dim strUserProfile As String = System.Environment.GetFolderPath(System.Environment.SpecialFolder.UserProfile)
'MessageBox.Show(strUserProfile, "Title")
Dim fileName As String = strUserProfile & "\Downloads\FaceToDXFExample.dxf"
Dim file As New System.IO.StreamWriter(fileName)
SharedVariable("DXF_Data_Exists") = False
' Write DXF header
file.WriteLine("0")
file.WriteLine("SECTION")
file.WriteLine("2")
file.WriteLine("ENTITIES")
For Each oEL As EdgeLoop In oFace.EdgeLoops
	For k = 1 To oEL.Edges.Count 'Each oEdge As Edge In oEL.Edges
		oEdge = oEL.Edges(k)
		oEdge_StopVertex = oEdge.StopVertex
		oEdge_StartVertex = oEdge.StartVertex
		oEdge_StopVertex_Coordinates = "X" & oEdge.StopVertex.Point.X & "Y" & oEdge.StopVertex.Point.Y
		oEdge_StartVertex_Coordinates = "X" & oEdge.StartVertex.Point.X & "Y" & oEdge.StartVertex.Point.Y
'				Dim oHSet As HighlightSet = oDoc.CreateHighlightSet()
'				oHSet.Color = ThisApplication.TransientObjects.CreateColor(185, 0, 0) 'Red
'				oHSet.AddItem(oEdge)
'					MessageBox.Show("Edge type is " & oEdge.GeometryType)
'				oHSet.Clear()
		If k = 1 Then 'first line in loop
			If oEdge.GeometryType = CurveTypeEnum.kLineCurve Or oEdge.GeometryType = CurveTypeEnum.kLineSegmentCurve Then
				PointCollection(oPointCol, oEdge_StartVertex.Point.X, oEdge_StartVertex.Point.Y,oTG,oSketch)
				PointCollection(oPointCol,oEdge_StopVertex.Point.X,oEdge_StopVertex.Point.Y,oTG,oSketch)
			Else
				CalculateEdgeStrokes(oEdge,oPointCol,oTG,oSketch)
		Else	'Line is not first line in loop
				oPreviousEdge = oEL.Edges(k - 1)
				oPreviousEdge_StopVertex_Coordinates = "X" & oPreviousEdge.StopVertex.Point.X & "Y" & oPreviousEdge.StopVertex.Point.Y
				oPreviousEdge_StartVertex_Coordinates = "X" & oPreviousEdge.StartVertex.Point.X & "Y" & oPreviousEdge.StartVertex.Point.Y
				If oEdge_StartVertex_Coordinates = oPreviousEdge_StopVertex_Coordinates Or oEdge_StartVertex_Coordinates = oPreviousEdge_StartVertex_Coordinates 'Good the start of the current line shares the start or stop of the previous line
				Else 'switch current line start/stop positions
			Else
	Next
	WritePointsToDXF(file, oPointCol)
	oPointCol.Clear
Next
'MessageBox.Show("Point collection contains " & oPointCol.Count, "Title")
'For i As Integer = 0 To oPointCol.Count - 1
'	oPoint = oTG.CreatePoint2d(oPointCol(i)(0), oPointCol(i)(1))
'	oSketch.SketchPoints.Add(oPoint)
'	MessageBox.Show("Point Added", "Title")
'Next
' Write DXF footer
file.WriteLine("0")
file.WriteLine("ENDSEC")
file.WriteLine("0")
file.WriteLine("EOF")
' Close the file
file.Close()
If SharedVariable("DXF_Data_Exists") = False Then
	System.IO.File.Delete(fileName)
End Sub
Sub PointCollection(oPointCol As List(Of Double()), X As Double, Y As Double, oTG As TransientGeometry,oSketch As PlanarSketch)
	If oPointCol.Count = 0 Then
		oPointCol.Add({X, Y })
'			oPoint = oTG.CreatePoint2d(X, Y)
	Else
		intLastIndex = oPointCol.Count - 1
		If oPointCol(intLastIndex)(0) = X And oPointCol(intLastIndex)(1) = Y Then
'			MessageBox.Show("Points are equal - will skip")
		Else
	Logger.Debug("X: " & X & ", Y: " & Y)
End Sub
Sub CalculateEdgeStrokes(oEdge As Edge,oPointCol As List(Of Double()),oTG As TransientGeometry,oSketch As PlanarSketch)
Dim lVertexCount As Long
Dim lSegmentCount As Long
Dim adVertexCoords() As Double = {}
Dim alVertexIndices() As Integer = {}
oEdge.CalculateStrokes(0.01, lVertexCount, lSegmentCount, adVertexCoords, alVertexIndices)
j = 1
For i = 0 To adVertexCoords.Length -1
	If j = 1 Then
		strCoord_X = adVertexCoords(i)
	Else If j = 2 Then
		strCoord_Y = adVertexCoords(i)
	Else If j = 3 Then
		strCoord_Z = adVertexCoords(i)
		PointCollection(oPointCol,strCoord_X,strCoord_Y,oTG,oSketch)
		j = 0	'reset the counter
	j = j + 1
Next
End Sub
Sub WritePointsToDXF(file As System.IO.StreamWriter, oPointCol As List(Of Double()))
SharedVariable("DXF_Data_Exists") = True
' Write lines to file
For i = 0 To oPointCol.Count - 2
    file.WriteLine("0")
    file.WriteLine("LINE")
    file.WriteLine("8")
    file.WriteLine("0")
    file.WriteLine("10")
    file.WriteLine(oPointCol(i)(0))
    file.WriteLine("20")
    file.WriteLine(oPointCol(i)(1))
    file.WriteLine("11")
    file.WriteLine(oPointCol(i+1)(0))
    file.WriteLine("21")
    file.WriteLine(oPointCol(i+1)(1))
Next
' Add the last line to close the shape
file.WriteLine("0")
file.WriteLine("8")
file.WriteLine("0")
file.WriteLine(oPointCol((oPointCol.Count - 1))(0))
file.WriteLine(oPointCol((oPointCol.Count - 1))(1))
file.WriteLine(oPointCol(0)(0))
File.WriteLine(oPointCol(0)(1))
End Sub
william
Ok, I have it now.
I used the Face.Evaluator.GetParamAtPoint() method.
Full working code below, might help someone else.
Sub Main()
Dim oFace As Face
Try
Catch
	Exit Sub
End Try
' Create a new file
SharedVariable("PosX") = 0	'Placeholder value
SharedVariable("PosY") = 0	'Placeholder value
	DXFHeader(file)
	ExportFace(oFace, file)
	'Add Text to the DXF file
	Call DXFAddText(file, "Text to add, line 1", SharedVariable("PosX"), SharedVariable("PosY"))
	Call DXFAddText(file, "Text to add, line 2", SharedVariable("PosX"), SharedVariable("PosY") - 5)
	DXFFooter(file,fileName)
End Sub
Sub CalculatePosX_PosY(oPointCol As List(Of Double())) 'Calculates the centroid of the dxf face by looking at all the vertices in the dxf
Dim Array_X As New ArrayList
Dim Array_Y As New ArrayList
For i = 0 To oPointCol.Count - 1
    Array_X.Add(oPointCol(i)(0))
	Array_Y.Add(oPointCol(i)(1))
Next
Array_X.Sort()
Array_Y.Sort()
minX = Array_X(0)
maxX = Array_X(Array_X.Count-1)
minY = Array_Y(0)
maxY = Array_Y(Array_X.Count - 1)
SharedVariable("PosX") = ((maxX - minX) / 2) + minX
SharedVariable("PosY") = ((maxY - minY) / 2) + minY
Array_X.Clear
Array_Y.Clear
End Sub
Sub DXFHeader(file As System.IO.StreamWriter)
' Write DXF header
file.WriteLine("0")
file.WriteLine("2")
End Sub
Sub DXFFooter(file As System.IO.StreamWriter,fileName As String)
' Write DXF footer
file.WriteLine("0")
file.WriteLine("0")
' Close the file
file.Close()
If SharedVariable("DXF_Data_Exists") = False Then 'dxf file was created but no line entities were written to it. Dispose of it
End Sub
Sub DXFAddText(file As System.IO.StreamWriter, TextToAdd As String, PosX As Double, PosY As Double)
file.WriteLine("  0")
file.WriteLine("TEXT")	'ENTITY TYPE
file.WriteLine("  8")
file.WriteLine("0") 'LAYERNAME
file.WriteLine("100")
file.WriteLine("AcDbText")
file.WriteLine(PosX) 'X COORDINATE
file.WriteLine(PosY) 'Y COORDINATE
file.WriteLine("30")
file.WriteLine("0.0") ' Z COORDINATE
file.WriteLine("40")
file.WriteLine("3.55") 'TEXT HEIGHT
file.WriteLine("  1")
file.WriteLine(TextToAdd) 'TEXT STRING
file.WriteLine("AcDbText") 'TEXT STRING
End Sub
Sub ExportFace(oFace As Face, file As System.IO.StreamWriter)
		oEdge_StopVertex_Coordinates = "X" & oEdge.StopVertex.Point.X & "Y" & oEdge.StopVertex.Point.Y & "Z" & oEdge.StopVertex.Point.Z
		oEdge_StartVertex_Coordinates = "X" & oEdge.StartVertex.Point.X & "Y" & oEdge.StartVertex.Point.Y & "Z" & oEdge.StartVertex.Point.Z
			If oEdge.GeometryType = CurveTypeEnum.kLineCurve Or oEdge.GeometryType = CurveTypeEnum.kLineSegmentCurve Then 'edge is straight
				PointCollection(oPointCol, oEdge_StartVertex.Point.X, oEdge_StartVertex.Point.Y, oEdge_StartVertex.Point.Z, oTG,oSketch,oFace)
				PointCollection(oPointCol,oEdge_StopVertex.Point.X,oEdge_StopVertex.Point.Y, oEdge_StopVertex.Point.Z, oTG,oSketch,oFace)
			Else 'Edge is curved, or spline, polyline, eclipse, ect
				CalculateEdgeStrokes(oEdge,oPointCol,oTG,oSketch,k,"","",oFace)
			oPreviousEdge_StopVertex_Coordinates = "X" & oPreviousEdge.StopVertex.Point.X & "Y" & oPreviousEdge.StopVertex.Point.Y & "Z" & oPreviousEdge.StopVertex.Point.Z
			oPreviousEdge_StartVertex_Coordinates = "X" & oPreviousEdge.StartVertex.Point.X & "Y" & oPreviousEdge.StartVertex.Point.Y & "Z" & oPreviousEdge.StartVertex.Point.Z
					PointCollection(oPointCol,oEdge_StopVertex.Point.X, oEdge_StopVertex.Point.Y, oEdge_StopVertex.Point.Z, oTG,oSketch,oFace)
				CalculateEdgeStrokes(oEdge,oPointCol,oTG,oSketch,k,oPreviousEdge_StartVertex_Coordinates,oPreviousEdge_StopVertex_Coordinates,oFace)
	Next
	If oEL.IsOuterEdgeLoop = True Then
		CalculatePosX_PosY(oPointCol)
	oPointCol.Clear
Next
End Sub
Sub PointCollection(oPointCol As List(Of Double()), X As Double, Y As Double, Z As Double, oTG As TransientGeometry, oSketch As PlanarSketch,oFace As Face)
	Dim oEval As SurfaceEvaluator
	oEval = oFace.Evaluator
	' Set the coordinate point where you want to get the corresponding
	' parametric point on the face. This point should lie on the face.
	Dim adPoints(2) As Double
	adPoints(0) = X
	adPoints(1) = Y
	adPoints(2) = Z
	Dim adGuessParams() As Double = {}
	Dim adMaxDeviations() As Double = {}
	Dim adParams() As Double = {}
	Dim alngSolutionNatures() As SolutionNatureEnum = {}
	Call oEval.GetParamAtPoint(adPoints, adGuessParams, adMaxDeviations,adParams, alngSolutionNatures)
	'MessageBox.Show("X: " & adParams(0) & ", Y: " & adParams(1))
	oPointCol.Add({adParams(0) * 10, adParams(1) * 10})
	'Logger.Debug("X: " & adParams(0) * 10 & ", adParams(1) * 10: " & Y)
End Sub
Sub CalculateEdgeStrokes(oEdge As Edge, oPointCol As List(Of Double()), oTG As TransientGeometry, oSketch As PlanarSketch, k As Integer, oPreviousEdge_StartVertex_Coordinates As String, oPreviousEdge_StopVertex_Coordinates As String,oFace As Face)
Dim oTempPointCol As New List(Of Double())
j = 1
	If j = 1 Then
	Else If j = 2 Then
	Else If j = 3 Then
		oTempPointCol.Add({strCoord_X, strCoord_Y, strCoord_Z})
	j = j + 1
Next
If k = 1 Then
    For i = 0 To oTempPointCol.Count - 1
        PointCollection(oPointCol, oTempPointCol(i)(0), oTempPointCol(i)(1), oTempPointCol(i)(2), oTG, oSketch,oFace)
    Next
Else
    strCurrentEdgeStartVertex = "X" & oTempPointCol(0)(0) & "Y" & oTempPointCol(0)(1) & "Z" & oTempPointCol(0)(2)
    If strCurrentEdgeStartVertex = oPreviousEdge_StartVertex_Coordinates Or strCurrentEdgeStartVertex = oPreviousEdge_StopVertex_Coordinates Then 'Good, the starting point of the current line is equal to either the start/end vertex of the previous line
        Next
    Else
        For i = oTempPointCol.Count - 1 To 0 Step -1
        Next
oTempPointCol.Clear
End Sub
    file.WriteLine("0")
    file.WriteLine("8")
    file.WriteLine("0")
Next
file.WriteLine("0")
file.WriteLine("8")
file.WriteLine("0")
file.WriteLine(oPointCol(0)(1))
End Sub
