Traingular notch on the bend lines
anuj16797
anuj16797
TO ACHIEVE
I'm looking for an ilogic to create notches of triangle shapes on the end of every bend lines on both sides pointing outwards.
PROBLEM
I combine a code to resolve the issue but i'm only able to create only single triangle and its not even on the bend line point.
@Curtis_Waguespack
@mcgyvr
@GeorgK
@tkddud711
@chandra.shekar.g
@JDMather
@CCarreiras
@Gabriel_Watson
@blandb
'[ edit these variables as needed
sSketchName = "Flat Pattern Sketch"
sHoleName = "Locator Holes"
oOffset = 0 'defines offset from edge of flat pattern
oDiameter = 0.125 'defines hole diameter
'  a reference to the active document.
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
'verify document type is sheet metal
If oPartDoc.ComponentDefinition.Type <> 150995200 Then
	MessageBox.Show("File is not a sheet metal part.", "iLogic")
	Exit Sub
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
' Check to make sure a flat pattern is open.
If Not TypeOf ThisApplication.ActiveEditObject Is FlatPattern Then
	Try
		If oCompDef.HasFlatPattern = False Then
			oCompDef.Unfold
		Else
			oCompDef.FlatPattern.Edit
	Catch
		MessageBox.Show("Error editting the flat pattern.", "iLogic")
	End Try
'  a reference to the active flat pattern.
Dim oFlatPattern As FlatPattern
oFlatPattern = ThisApplication.ActiveEditObject
'clean up existing holes
Dim oHole As HoleFeature
For Each oHole In oFlatPattern.Features.HoleFeatures
	oHole.Delete
Next
Dim oFace As Face
'oFace = oFlatPattern.BottomFace
oFace = oFlatPattern.TopFace
Dim oSketch As PlanarSketch
'clean up existing sketch
For Each oSketch In oFlatPattern.Sketches
	If oSketch.Name = sSketchName Then
		oSketch.Delete
Next
' Create a new sketch.  The second argument specifies to include/not include
' the edges of the face in the sketch.
oSketch = oFlatPattern.Sketches.Add(oFace, False)
' Change the name.
' Create a new object collection for the hole center points.
oHoleCenters = ThisApplication.TransientObjects.CreateObjectCollection
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Dim oPoint As Point2d
Dim oSketchPoint As SketchPoint
'oOffset = oOffset *1 'converts cm to inches
Dim oEdge As Edge
Dim oEdges As Edges
' Get all Bend UP edges
'where true = top face
oEdges = _
oFlatPattern.GetEdgesOfType( _
FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge, True)
For Each oEdge In oEdges
    Dim oLine As SketchLine = oSketch.AddByProjectingEntity(oEdge)
	'yMinPoint = oLine.RangeBox.MinPoint.Y
	yMaxPoint = oLine.RangeBox.MaxPoint.Y
	' Create a vectors along the y-axis.
	Dim oVec_Y As Vector2d
	Dim oVec_Y_neg As Vector2d
	If yMaxPoint < 0 Then
		oVec_Y1 = oTG.CreateVector2d(0, oOffset)
		oVec_Y2 = oTG.CreateVector2d(0, oOffset)
	Else
	oSketchPoint = oSketch.SketchPoints.Add(oLine.StartSketchPoint.Geometry, True)
	oSketchPoint.MoveBy(oVec_Y1)
    oHoleCenters.Add(oSketchPoint)
	oSketchPoint = oSketch.SketchPoints.Add(oLine.EndSketchPoint.Geometry, True)
	oSketchPoint.MoveBy(oVec_Y2)
    oLine.Delete()
Next
' Get all Bend Down edges
oEdges = _
FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge, True)
	Else
    oLine.Delete()
Next
Dim oBotDia As Double = .144
Dim Sides As Integer = 3
'create check sketch
Dim oPolygon As SketchEntitiesEnumerator
Dim oCircle As SketchCircle
oGC = oSketch.GeometricConstraints
oDC = oSketch.DimensionConstraints
oCP = oSketch.AddByProjectingEntity(oCompDef.WorkPoints.Item(1))
oPolygon = oSketch.SketchLines.AddAsPolygon(Sides, oSketchPoint, oTG.CreatePoint2d(0,0), True)
    'Make Lines Construction
    For Each oLine In oPolygon
	     oLine.Construction = False
	Next
    'Variable to capture center of Polygon pattern
    Dim polygonCP As SketchPoint
    Dim verifyType As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
    For Each sp As SketchPoint In oSketch.SketchPoints
	    'Centerpoint of the Polygon seems to have (2 x Sides) PatternConstraintObjects
	    'You might need to do extra checks if you will have multiple Polygons in your sketch
	    If sp.Constraints.Count >= 2 * Sides
		     For Each Item In sp.Constraints
			     If Item.Type = ObjectTypeEnum.kPatternConstraintObject Then verifyType.Add(Item)
		     Next
		         If verifyType.Count = 2 * Sides
			     polygonCP = sp
			     Exit For
    Next
    If IsNothing(polygonCP) Then MessageBox.Show("Could Not find a Polygon CenterPoint", "Failure") : Exit Sub
    'Constrain sketch
    oGC.AddCoincident(oCP,oSketchPoint)
    oGC.AddVertical(oPolygon.Item(2))
	oDC.AddOffset(oPolygon.Item(2),polygonCP,oTG.CreatePoint2d(0, oBotDia / 4 * 2.54), True).Parameter.Value = (oBotDia * 2.54)
    ' Create the hole feature.
    'oHole =  oFlatPattern.Features.HoleFeatures.AddDrilledByThroughAllExtent( _
                            'oHoleCenters, oDiameter , kPositiveExtentDirection)
							'oHoleCenters, oDiameter * 2.5400013716 , kPositiveExtentDirection)
	'oHole.Name = sHoleName
	'oSketch.Visible = True
wowrs1608
Like this?
anuj16797
Like the file i have attached below.
triangle pointing outward at every centerline.
wowrs1608
Curtis_Waguespack
Hi @anuj16797
See the attached Inventor 2022 example file and the Rule text file (if you can not open Inventor 2022).
I hope this helps.
Curtis
coryYN9VQ
@Curtis_Waguespack ,
Is this possible to do using the unfold command and then refold the part to maintain the usage of the folded model?
I have a highly convoluted and modified version of a similar method, but cannot seem to get it working proper.  I can get the model unfolded but finding centerlines is apparently impossible(?)...the flat pattern automatically places the centerlines for the rule to then pull info from.  I need to do the same but in the unfolded state rather than the flat pattern.
I have even tried to project the centerlines from the flat pattern onto the sketch in the folded model, but the flat pattern coordinate system never seems to match up with the folded model's coordinate system.
So basically:  could your code be modified to do the exact same thing but on the folded state?  I have yet to find a method...
