Tolerances as a dropdown
DIMCWPDR
DIMCWPDR
Hello everyone
I need to create a dropdown menu for "Tolerances" that i can easy change between them and in the sametime i can see the changes on the drawing, normally I use 4 deferences tolerances on my drawings.
I have tried by add a Form and add Tolerances from  iProperties - Custom but i can only write on that titelbox see the pic.image.pngimage.png
How to make a Rul or Form by ilogic that to do that?
youann21700
From my experience (limited), drop downs are only available as Parameters in a form rather than an iProperty.
if you had a rule that ran to define your list of possible tolerances first
(eg.
MultiValue.SetList("Tolerances","1","2","3")
You should be able to insert this Parameter into a form and choose the drop down option.
What are you wanting to do with the chosen value?
