Toggle Textbox Option In Format Text Window Using iLogic
gareth.butlerS9R7M
gareth.butlerS9R7M
Hi All,
I have cobbled together some iLogic code which formats text, sets justification etc in part (.IPT) sketches.
I can't seem to get any of the code to toggle on or off the textbox button.
How can I add to / vary the code sample below to either enable or disable the textbox button?
Dim oPartDoc As PartDocument
oPartDoc = ThisDoc.Document
Dim oCd As ComponentDefinition
oCd = oPartDoc.ComponentDefinition
Dim oTextbox As TextBox
Dim oSketch As PlanarSketch
Dim oColor As Color = ThisApplication.TransientObjects.CreateColor(128, 0, 128)
For Each oSketch In oCd.Sketches
For Each oTextbox In oSketch.TextBoxes
'write formatted text
oText = oTextbox.Text
oTextbox.Color = oColor
oTextbox.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextCenter
oTextbox.VerticalJustification = VerticalTextAlignmentEnum.kAlignTextMiddle
oTextbox.WidthScale = 1
oTextbox.FormattedText = "<StyleOverride Font='Tahoma' FontSize='0.35' Bold='False' Italic='False' Underline='False'>" & oText & "</StyleOverride>"
Next
Next
iLogicVb.UpdateWhenDone = True
Any help or advice greatly appreciated!
Many thanks,
Gareth 😀
frederic.vandenplas
There is no API available for that, but you can allways use the native command for that
In this example i preselected the text, and executed the code below (vba)
If you run it a second time the textbox wil revert in the previous state.
You can check with the textbox.Fitted property if you need to convert your textbox.
Here you can find all the information you need
    ' Get the CommandManager object.
    Dim oCommandMgr As CommandManager
    Set oCommandMgr = ThisApplication.CommandManager
    ' Get control definition for the line command.
    Dim oControlDef As ControlDefinition
    Set oControlDef = oCommandMgr.ControlDefinitions.Item( _
                                                 "SketchTextAddDelBoxGeomCmd")
    ' Execute the command.
    Call oControlDef.Execute
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
WCrihfield
Hi guys.  I believe there is actually a way to do this by API, instead of needing to select it then execute a command on it.  But first things first.  In your original code here, you would need to change your
to this:
Dim oTextbox As Inventor.TextBox
...because it gets confused with the System.Windows.Forms.TextBox object.
Next, the Inventor.TextBox object has a couple properties we can use for this task.
TextBox.ShowBoundaries (Read/Write Boolean - like the 'TextBox' button in the dialog)
TextBox.BoundaryGeometry (ReadOnly - SketchEntitiesEnumerator type value)
That first property is like the TextBox button in the editor dialog, while that second one provides a way to get a reference to the actual geometry objects (SketchLine objects) that make up its border, so you can apply sketch level constraints to them.
Wesley Crihfield
(Not an Autodesk Employee)
gareth.butlerS9R7M
@frederic.vandenplas @WCrihfield
I changed the code to that below by adding in the oTextbox.ShowBoundaries line and it now does what I need it to.
During the iLogic execution, the text is automatically converted to textbox toggled 'on' because the boundary has been set to show.
oTextbox.ShowBoundaries() = True
Next
Next
Brilliant work and thanks for all your help, it is greatly appreciated! 😀👍
frederic.vandenplas
@WCrihfield
I've overlooked that property, sorry for that!
WCrihfield
No need for apologies.  You were just trying to help.  I'm sure I have done the same or worse many times before.  Some of this stuff can be tricky.  The tooltip for the button says 'Text Box', but the property is named 'ShowBoundaries', so they do not seem like the same thing on first glance.  Sometimes these little details just stick better in our head once we have been tripped up by them before.  The process of trial & error is a very effective teacher.
Wesley Crihfield
