Toggle Blues and text boxes
Message 1 of 10
Does anyone have a good workaround for making toggle buttons in VB6 other than using a
image control with multiple pictures?
The real problem I am running into is that I am in a DoEvents loop and if I press a button
it sees it, but it doesn't seem to see any of the click events on a image control.
Also one time Brian shared with me a easy way to mimic the standard Inventor textbox so as
to only allow valid distance entries. I foolishly didn't write it down and can't remember
how to do it. Anyone know how to do it?
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
Replies (9)
Message 2 of 10
So you want to change a button that says "on" to "off" when it's clicked
(and vice versa?)
if command1.caption = "on" then
command1.caption="off"
else
command1.caption="on"
end if
or am I missing the point?
I'd like the know the answer to your last question. I had that one also but
misplaced it.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Kent Keller" wrote in message
news:80DAD0D6B19F57B53D308C2E59D0F87A@in.WebX.maYIadrTaRb...
than using a
I press a button
control.
and can't remember
> Kent
> Assistant Moderator
Message 3 of 10
No, I am trying to mimic a VBA toggle button. Press it and it stays down. VB doesn't
have such a control.... at least that I have ever been able to see. The only way I have
been able to do it is to take a image or picture control and swap pictures to make it look
like a button down on the mousedown event.
I have just figured out that a Picture control mouse click is seen while in a DoEvents
loop, but a Image click isn't??? 8^(
I have always kind of preferred the Image control, but am in the process of changing over
8^/
And yes the second question is one I would really like to know. Promise I will write it
down this time. 8^)
Kent
Assistant Moderator
"Sean Dotson" wrote in message
news:5883CEEBCEEAF87A83FD9EAE100B15EF@in.WebX.maYIadrTaRb...
> misplaced it.
> Sean Dotson, PE
Message 4 of 10
You can do this. Go to the toolbox. Insert a Toggle Button. You can insert
it as a frame with more than one button or one toggle button on its own.
Kathy Johnson
Message 5 of 10
Well about the only thing I know for sure right now is that I am confused. 8^))
It appears that if I have a image in either control it isn't seeing the click event, but
if I add either a image control or a picture control without a picture then it does trap
on the event???
Kent
Assistant Moderator
news:0E03728042A392A1C9EC15D3F8EE7639@in.WebX.maYIadrTaRb...
Message 6 of 10
Thank you Thank you thank you At first I thought you were just talking about VBA
which has a toggle button, but then I inserted a Option button and started looking through
the properties and you can turn it into a button. Weird, even a FAQ I found out on the
web said you had to use Images. LOL
Kent
Assistant Moderator
"KJohnson" wrote in message
news:04BE1EE5158B2D5D66ABD82CA93D1088@in.WebX.maYIadrTaRb...
> Kathy Johnson
Message 7 of 10
I hate looking like a fool even though I do it so well 8^)
I think I figured out why the click event wasn't working before. I was setting the
Enabled state to False in the code, and I thought I had it in a different spot than I did.
With the image controls being disabled doesn't change their appearance much so it wasn't
obvious. When I switched to a graphical option button it became a little more obvious.
8^)
Through all this mess I hope the Textbox issue doesn't get buried.
Kent
Assistant Moderator
news:781CF272CC851C37E5F9AA418C13D56E@in.WebX.maYIadrTaRb...
Message 8 of 10
Here's the answer to your second question. Here's the code for the Change
event of a text box that will perform this validation.
Private Sub txtLength_Change()
' Check to see if expression entered is valid.
On Error Resume Next
Dim dValue As Double
dValue =
ThisDocument.UnitsOfMeasure.GetValueFromExpression(txtLength.Text, _
kDefaultDisplayLengthUnits)
If Err Then
txtLength.ForeColor = vbRed
Else
txtLength.ForeColor = vbWindowText
End Sub
Brian Ekins
Developer Technical Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
than using a
I press a button
control.
and can't remember
> Kent
> Assistant Moderator
Message 9 of 10
Thanks Brian Always seems so easy when you see it in black and white, and so hard when
you are trying to figure it out yourself 8^)
Kent
Assistant Moderator
"Brian Ekins (Autodesk)" wrote in message
news:0B31C811C37AA78F408E9EFBCF0A98A4@in.WebX.maYIadrTaRb...
Message 10 of 10
Does it seem odd that this doesn't work
dValue = oUOM.GetValueFromExpression(txtOffset.Text, 11266)
sVal = oUOM.GetStringFromValue(dValue, 11266)
But this does?
sVal = oUOM.GetStringFromValue(dValue, kDefaultDisplayLengthUnits)
Is my understanding correct, that to be sure the code can be run in any
language, you should always use the Enum instead of the name ?
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
> dValue =
> If Err Then
> Else
> End If
> End Sub
